Question about Canon PIXMA iP2000 InkJet Printer
Printer won't print, loaded up
Followed instructions to set up ip 2000 to laptop [acer aspire 5100] everything loaded but when trying to print says printing error
  • 39 Answers
At first you disconect your printer cable. and reset your laptop then conect printer cable and anstall driver auto.setup printer driver and chack test print.
Posted on Jan 22, 2008
I had the waste ink full problem and fixed that but now it won't print black and when I try cleaning it reports error 5100 I know all cartridges are full.
Is it canon ip-?
If yes, Try to follow these instruction:
Steps to Fix Error 5100 In the Canon IP- Printer:
  1. Turn the printer off
  2. Remove the cartridge from the printer
  3. Use a cloth moistened with alcohol to clean the surface of the contact / connector terminal cartridge that touches the printer / could also use a pencil eraser
  4. Replace the second Cartridge
  5. Turn on the printer.
Thank you
Jun 07, 2011 | Office Equipment & Supplies
My laptop has the case damaged and i need to replace it notthe part with the screen just the bottom 2 parts
Hi
Thank you for your query
Unfortunatley this is a massive job involving taking everything (and i really do mean everything apart)
This is something i would not recommned you do, it would be far to difficult to put this into words, so i would recommned that you take the laptop to a reputable PC shop to swap out for you
The casing can be bought relativley cheaply of ebay
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | Acer Aspire 5100 Notebook
My Acer 5100 can not connect to the Internet
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
If you need user name and password for connect to your service prtovider then configurayour router as PPPOe .
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 08, 2010 | Acer Aspire 5100 Notebook
Acer laptop printing looses contact with printers
have you uninstalled the other drivers completely and THEN reinstalled the new drivers? that's probably your problem.
Dec 04, 2009 | Acer Aspire 5100 Notebook
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process. http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Jan 17, 2009 | Acer Aspire 5100 Notebook
Startup repair fails to fix the problem
Try reinstalling windows. Insert a the windows cd into the drive and restart your computer, than follow instructions.
Dec 31, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 laptop drivers for xp
there should be all the drivers here, just choose the XP listing and then click the driver you want
Sep 01, 2008 | Acer Aspire 5100 Notebook
Aspire 5100
Sounds like both of you have what is called 'Microsoft Blue Screen Of Death' and is irreversible, but is fixable at the same time. If you need files on your computer then follow these instructions
  1. Turn on computer and Insert Windows XP Installation Disc that came with your computer
  2. Wait until it says 'Press any key to boot from CD....' and press any key
  3. Wait until it comes up with prompts and choose 'Install Windows XP
  4. Choose to install XP without formatting the hard drive and choose a made partition (C Drive) to install NTFS
  5. Install and now your system will be working again. You will be prompted from now on though which Operating System you would like to use. Always select the first one
  6. Enjoy
For if you want to erase the hard drive
  1. Follow steps 1 - 3 in above instructions
  2. Choose 'Format Hard Drive'
  3. Select create partition in Hard Drive and set it to the maximum space and call (C)
  4. Select NTFS and go through instructions
  5. You won't be asked to choose a OS as there is only one to choose from
  6. Enjoy
Hope This Helps
Aug 06, 2008 | Acer Aspire 5100-5022 Notebook
How to print from Acer Aspire 5100 Laptop
have you tried uninstalling the software and then reinstalling? I had same problem and that seemed to fix it for some reason.
Jul 06, 2008 | Acer Aspire 5100 Notebook
Canon PIXMA iP2000 InkJet Printer Logo
80 people viewed this question
old marine
old marine
