Question about Toshiba D-VR4 DVD Recorder/VCR
Dvd says it starts to record then just stops
I am recording from another machine, when i push record on the dvd side it starts to count up, gets to about 11 seconds, and then just stops.....im using dvd-r and it seems to read the disk fine.....any ideas or solutions?
  • 4TheAnimals Jan 01, 2009
    When I try to record from my TV DVR list it starts recording then stops at 26 seconds and restarts the machine
  • 107 Answers
Have you tried to use dvd-rw? or try other movies to record with it.
Posted on Jan 24, 2008
Cannot get the dvd out of my recorder, will not eject with remote or the button on the recorder
Look on the face of the DVD drawer. You will see a tiny hole in it. Straighten a paper clip and push it in the hole until it stops. Push further and the drawer will open mechanically far enough for you to grab it and open it completely.
Jul 28, 2017 | Magnavox MWR20V6 DVD Recorder VCR Combo
You've recorded a track. You hit Stop. You want to capture more of the conversation in the room, so you FORGET to hit New Track, and instead push the record button. Which resets the already-recorded...
Yes, it's gone.
This is the one glaring fault with the 9600, if you select a previously-recorded track, and hit 'record', and then 'play', there's no failsafe, or 'are you sure?' prompt to remind you that there's already content within that track.
If you select the track, and ONLY hit 'record', putting the machine into record standby, but don't hit 'play' to start recording, your previous content is saved when you hit 'stop' - record standby doesn't overwrite anything.
Dec 08, 2010 | Alesis MasterLink ML-9600
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Stopped recording/won't open door for disc at all
There's a slot on the bottom where you can insert a small slotted screwdriver and slide it to the left to get it open.
Apr 03, 2009 | iLO DVD Recorder DVDR05
Dvd-vr357
I do this all the time. Press Menu on your remote control. From there go to Copy then select VCR-->DVD. If you're recording from the beginning of a tape just press the Enter button. If you're recording from another place on the tape hit Play or FF to advance you to the spot you want to start recording. Stop the tape where you want to record from and hit Enter. FF to the place on the tape where you want your recording to stop. Stop the tape where you want the recording to end and hit Enter. Hit the Down Arrow on the remote control to highlight Copy All and hit Enter. Your machine will rewind to the start point and begin recording and it will stop when you get to the indicated end point. Note: If you have more than one episode/show on a VHS tape and you want separate titles for each, you have to go through this process for each title. If you have more than one start and end point for each copy command you'll just get different chapters not different titles. I hope that made sense!!! Hope this helps you out.
pjrsop
Apr 24, 2008 | Samsung DVD-VR357
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
Open Questions:
See all Toshiba D-VR4 DVD Recorder/VCR Questions
Toshiba D-VR4 DVD Recorder/VCR Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
