Question about Projection Televisions
I have a samsung ps50p96fd plasma tv i veiw my pc through it but the problem is when i open a new window on the pc it creates a dark imege like a gray shadow outside of the new window which makes the background imege darker what is this and can you help
4 Suggested Answers
  • 790 Answers
SOURCE: Dark Screen and Blue Lines Arc Across Background
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Posted on Dec 28, 2007
  • 188 Answers
SOURCE: Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Posted on Sep 17, 2008
Seth Wolf
  • 12 Answers
SOURCE: dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Posted on Feb 02, 2010
  • 1447 Answers
SOURCE: The picture of my HD56G786
problem on high voltage .some of components are go to bad ,so replace this damage part quickly by authorized service center.
Posted on Nov 20, 2010
0 characters
1 Points
How do I fix a Samsung tv model htp5054x/xaa? I have power and I can hear audio but no image.
First trouble shooting steps is to try a different source, or at least a different cable. A bad HDMI cable can allow sound but not image. Also look closely at the screen. If you can see a dark image, it would indicate that the lighting system has failed. Check this video for some tips. Samsung Plasma TV Repair How to Repair and Replace Main Board
Sep 07, 2015 | Samsung Projection Televisions
Tv screen is very dark after turning brightness all th way up
You bulb is shot. They are expensive, time to get a new plasma.
May 04, 2010 | Panasonic PT-51G44 51" Rear Projection...
Part number for color wheel
That model is a plasma TV? Plasma TV's don;t use color wheels. Only the DLP sets do.
Aug 15, 2009 | Samsung Projection Televisions
Plasma will not turn on
Power supply is defective. Caution: high risk to open the tv. There are voltages that can give you a heart attack.
Apr 15, 2009 | Projection Televisions
TV has dark streak on one side of screen.
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Picture dark
Please check its G2 (grid) volts, should be approx 600-700 volts dc. In some sets it calls Screen Volt.
Aug 09, 2008 | Toshiba 42H83 42" Rear Projection...
Projection Televisions Logo
22 people viewed this question
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
