Question about HP PSC 1315 All-In-One InkJet Printer
USB Problem My printer would not recognized the USB. I dont know what to do. I tried the USB Cord elsewhere and it works, I as well tried another printer on the USB Port, it as well works.
  • 23 Answers
Your Printer haveing Logic Board Problum so go to near by service center if you don't find if you are from mumbai then call on 9322133048
Posted on Jan 22, 2008
Windows 7--64 bit. USB port, was working. Had power outage due to lightning striking corner of house, burned out some breakers. Printer was on surge protector, but printer and PC not powered off prior to...
See if printer will work in another working computer. If it does the issue is with your computer hardware/software. If it also does not work then the issue is with the printer. And if so, it is not cost effective to repair given the price of printers these days.
Mar 03, 2017 | Brother MFC495CW AllInOne InkJet Printer
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
My lexmark 2350 im trying to set it up and my computer keeps telling me that i need to change the port to a usb and i found how i just dont know which port there is tons of them
Aquick fix for most communication errors can be achieved by resetting theprinter and/or rebooting the PC. Simply disconnect the printer from yourcomputer. Reboot your pc. Unplug and re-plug the printer into the power sourceto reset it. When the printer turns on, reconnect it to your computer. Then tryto print again once the computer fully recognizes the USB connection. Ifthat doesn't help, try the steps below: 1.Disconnect the printer from your computer. 2.Rebrick (pull out power supply, black box where thepower cord is plugged in at the back of the printer, and put it back after 30seconds). 2.On your computer, go to Control Panel > Printers and Faxes. 3.Delete the Lexmark print object. 4.Reboot your pc. 5.When your pc turns on, reconnect the printer. 6.Wait until your pc fully recognizes the USB connection. To check, go to ControlPanel > Printers and Faxes. If you see a new Lexmark print object in thelist, then try to print again.
Youmay also try to update your printer driver by visiting the Lexmark website at http://bit.ly/qQJd8g.Select your operating system, download and execute the file.
Ifthe problem continues, please contact Lexmark Technical Support Center foradditional assistance.
Aug 14, 2011 | Lexmark X2350 All-In-One InkJet Printer
Need usb cord
Hello
You can for example use this "USB 2.0 AM-BM Printer Cable"
http://www.dealextreme.com/details.dx/sku.750
Apr 21, 2009 | Dell 924 All-in-One InkJet Printer
MY COMPUTER SAID IT DOES NOT RECOGNIZE MY USB CORD
It will never say it doesn't recognize a USB cord.
A USB cord is just that--a piece of wire. It might tell you that it can't find the printer.
Has the printer worked before?
If you are installing it for the first time, did you install the software before plugging in the printer?
If you have done all these things, then either the USB port is bad or the printer is.
But--try uninstalling the printer first--and any software that came with it. Then reinstall the software and plug in the printer.
While I did mention that the cord is just a piece of wire, it is possible that the cord has become damaged in some way. Try using a different cord. Also, try using a different USB port.
Apr 18, 2009 | HP LaserJet P2015dn Printer
Olympus C-3000Z and Vista, can't unload
i have an olympus c-3000 more don"t instalaction automatical to windows i dont have the softwear for instalaction : cd ok
Aug 22, 2008 | Olympus C-3000 Zoom Digital Camera
Hp officejet 5610 all in one printer
you can use the serial/usb adaptor to connect it to your computer
May 07, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
