Question about Casio Exilim EX-S600 Digital Camera
Pictures with Casio Exilim EX S600 outside far too bright
My camera worked fine until about six months. Pictures outside are far too bright. Pictures with flash and videos are ok. What can I do? I really like the camera and would like to find a solution. Pictures outside are almost white, pictures inside with flash are normal, also videos.
SOURCE:
  • 63 Answers
SOURCE: CASIO EXILIM EX-S600 - software needed
here's you go http://world.casio.com/qv/download/en/
Posted on Aug 13, 2007
  • 641 Answers
SOURCE: Casio Exilim EX-S600 LCD broken. Needs spare part
From which country are you from ?
Posted on Aug 27, 2007
  • 374 Answers
SOURCE: casio camera card error
It could be either a brand that is not supported or there could be something wrong with your card. Casio only recommends Sandisk, Toshiba and Panasonic memory cards. Try one of those brands and make sure you format it with your camera before trying to save pics to it.
Posted on Nov 26, 2007
SOURCE: casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
Posted on May 25, 2008
mydc
  • 33 Answers
SOURCE: casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Posted on Aug 15, 2008
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Too much brightness
Set the ISO to a lower number and make sure your "exposure compensation" is at "0" or lower if you prefer.
Jul 04, 2010 | Olympus Stylus 710 Digital Camera
Casio S600 Exilim takes outdoor overexposed pictures
Check the ISO ( film speed (ASA) that you have set change it to either 100 or 200 and even 64 if it allows that.
You need to have the shutter snap fast in sunny/bright conditions and the Aperture needs to be a large number like F11
The higher the number the smaller the aperture ( sharper image not bleached out) F4 can be too large so can F8 in many cases and will, combined with the wrong ISO ..overexpose your pictures.
Please rate the help ++++Thanks for using FIXYA
Sep 26, 2009 | Casio Exilim EX-S600 Digital Camera
Pictures are extremely bright
Over exposure due to the shutter not closing over the lens. try taking video and see if that comes out ok. Another way to test the theory is to put your camera into full optical zoom and turn the flash off so as not to blind yourself and turn the camera to face you and angle the lens so that you can see into it without reflection. now take a picture and watch the shutter closely. In full optical zoom it should bring your internal lens right up to the front end of the lens so that you can see it clearly( this would depend on your camera though). Does the shutter cover the lens completely? it should do. If it doesn't then something is sticking it or obstructing it.
The video is a good indication of a faulty shutter as this does not use it so should work ok.
Only way to solve it completely is to strip it down and clean it.
Apr 04, 2009 | Cameras
Blurry bright pictures
1.go to menu go to quality and put in fine. make sure also that your flash is on during the night and your not moving the camera around while your taking pictures.
Oct 12, 2008 | Samsung Digimax D53 Digital Camera
Pictures taken outdoors are too bright
This issue is caused by either a defective CCD or main-board one or the other needs to be replaced. You can go to www.digitalcamrepair.com if you need further assistance.
Sep 29, 2008 | Casio Exilim EX-S600 Digital Camera
Exposure wheel does not seem to have the proper range.
the scroll button is already losing contact that why is not working properly..use a lighter fluid to the button then roll up and down untill the button is clean don't put to much fluid ok...
Aug 06, 2008 | Sony Handycam CCD-TRV68 Camcorder
Over exposure
Hey - have the same problem. All my still pictures are coming out overexposed, no matter what setting I use. Tried resetting, tried new battery, tried new memory card, tried different exposure settings. Nothing fixed it or affected it. However, my movie exposure works great so I can take movies just fine. Are you able to take movies with no overexposure?
Jul 25, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Casio exilim EX-S500 overexpose
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
210 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
