Question about Fuji FinePix S7000 Digital Camera
FUJI FINEPIX S7000
When I switch the camera on I get the Fine Pix Logo and then screen goes dark and the camera goes dead ( the camera lens does not retract)
Any suggestions?
  • 3 more comments
  • dodolook Jan 24, 2008
    Yes I do put fully charged 2000mah batteries
  • aboross Feb 27, 2008
    I have the same problem. I used the camera about 3 weeks ago. I picked
    it up today and shows low battery and shuts down. Charged two sets of
    photo batteries. Same story.
  • fireball1 Apr 29, 2008
    when i switch on i get focus error on the screen and the lense does not retract, i have tryed switching on and off a few times but nothing happenens
  • Anonymous May 11, 2010
    does it have enough battery?
This sometimes happens when the camera has been dropped or even bumped too hard. If while using strap you hit conner of chair it can be just enough to cause this problem.
Posted on May 03, 2008
Posted on Apr 16, 2008
Posted on Apr 15, 2008
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Posted on Feb 27, 2008
6ya staff
SOURCE:
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
Fuji Fine pix S7000 looses settings when batteries are bieng char
yes, there is a battery,to keep the settings,rarely it happens,open the camera see for a button cell replace it.
Apr 06, 2010 | Fuji FinePix S7000 Digital Camera
Power on to take picture, but view finder is dark, and snapping a picture, provides a black picture.
Hi!
Probably the CCD is dead. It's a well known problem with S7000. It's a hardware problem, the CCD has to be changed. For S7000 it usually comes with the lens and it makes the repair quite expensive. It's about 250-300$ here. You should contact your local Fujifilm service center.
I work in a camera service center authorized by Fujifilm.
Sorry for the bad news!
Tom
Aug 01, 2009 | Fuji FinePix S7000 Digital Camera
How can I reset my S7000 fuji fine pix?
Turn Camera on, Turn Dial to SET and scroll down on the screen to reset
Jan 13, 2009 | Fuji FinePix S7000 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Camera fine pix s 1000
you can download drivers for your camera from your camera manufacturer
Sep 30, 2008 | Fuji FinePix S7000 Digital Camera
CCD failure on Finepix s7000
You have to replace the CCD if it is dead. It usually runs about $150-200. It will come as part of the lens block assembly.
Jul 21, 2008 | Fuji FinePix S7000 Digital Camera
Fuji fine pix s7000 flash not working
Check to see if the flash has been set to a lower power or underexposes via a +/- setting. If not, warranty repair unless the camera has been damaged.
Sep 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
193 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
