Hi I own a Haier 27 inch Flat screen
Model: HFT27R11
Serial # 09045020c9520030 25A0396
I heard a thump thump thump out of the speakers and looked up and the screen was off but the power light was flashing and with every flash the thump noise out of the speaker.
Please help me it is the only TV and it is only a couple of years old I do not smoke in my home and the TV has not been moved I don't understand this.
Thank You
Tim Terzich
Seriously its a difficult problem, well sometimes the system control needs a heat-up by resoldering it. or caused by the flyback and the horizontal transistor. reply me if the problem persist. ^.^
both are same tvs to me but it depends on what is used inside, wether the best material or easy to blow.. ok ^.^ tvs are the same we watch on them, but when a person dont care about the things use, well its easy to worn out. so if you're having your things to important to you. you should take care of them and they will give you what the best they ca give you.. ^.^
thanks for the reply ^.^
reply if it the problem persist.. (",)
SOURCE: Haier 27 inch Flat screen TV I think power problem
you may need to do this ...i have a similar problem and have been searching weeks to fix it ...even calling local tv repair shops ...they all charge too much....check this out http://www.jiaoyou8.com/friends_pics/I/IVYBOY/IVYBOY_594471_62e1b717cef2ae57f2f7e59c886f9f0178122d63.jpg YOU CAN FIND THESE PARTS IN YOU LOCAL RADIO SHACK GET A SODERING IRON A SMALL L KEY ...and get to work i did it my advice is to pull on it while applying the iron from th other side.....
Thank You I will try that. Say can I ask if a JVC AV-27S33 27 inch TV is better than my Haier 27 inch flat screen HTF27R11
Thank You Again
Tim
Model: HFT27R11 Serial # 09045020c9520030 25A0396
I heard a thump thump thump out of the speakers. I disassembled the TV and there is a ticking noise below the flyback, mabey the smaller transformer? Screen is black. The power light is flashing with every ticking noise.
Can anyone please help me? It's only a couple years old.
Thank You in advance,
Tim Terzich
