HP Compaq nx6110 PC Laptops
Problem for HP Compaq nx6110 PC Laptops
Nx 6110 boot up issue
By taahir on Jan 22, 2008
hello all, my laptop was bought 2nd hand, it takes 10 minutes from the time i push power button to display the initial boot up screen( in this case the HP boot screen). but after that it boots and shuts down perfectly until i turn it off n leave it alone for over an hour and the problems starts again. please help
Same Problem
Jan 24, 2009
-   a 5 year old toshiba satellite 1405-s51 takes for ever to boot up-   Guest
Aug 04, 2008
-   When i installing the os then error is ..Can not find my hard disk -   Guest
Best Solution
posted on Jan 24, 2008
Helpful)
danasaur
Rank: Guru
Rating: 87%, 110 votes
None of the above. Sorry. All those "solutions" are "shooting in the dark". There is a definitive method of determining the problem here, without guesswork.
The "HP screen" you speak of is an "advertising mask" governed by the "quiet boot" option in BIOS.
This HP screen is shown INSTEAD of showing you exactly what BIOS is "doing" at that moment: First, a ROM checksum to verify BIOS is OK, then a quick system check of the most basic components, and if that goes well, the next thing it does is count AND check the RAM. Finally, after all that is done, it will look for a hard drive and query that drive for cylinder or LBA size, then look at MBR for sector zero, to find an operating system.
So here is what you must do to SEE all that taking place:
1. Make sure the system is TOTALLY cold (off, not in any ACPI state). Do this by pressing and holding the power button for 10 seconds, then release.
2. Remove Battery and the PSU (AC power supply)
3. Insert the PSU connector (only) this will also eliminate any battery problems. Batteries with dead cells can pull out so much current that you get slow boot/running performance. More on this later.
4. Now, start the computer, and keep pressing ESC key, quickly. It may start beeping. Stop and wait then.
5. Next, you will see a BLACK screen instead of HP screen. There will be some white text that scrolls. First the BIOS type and version. Next, RAM will be counted, and last, a HD will be reported. Last (or if any of the above have a problem) any errors will be reported. Some BIOS will specify the error, others will report it as "code XXX". Send me (post) this info, and I will analyze the problem.
NOTE: you can hit the PAUSE key at any time, to read the info, if it runs too fast for you. Then press PAUSE key again, to resume the BIOS data post process. Once you have reported back with any errors (as in step 5 above), we can also do this same thing with Windows, to "see" the black screen/errors reported as the PC boots.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jun 16, 2009
Somewhat Helpful)
kushwaha_001
Rank: Apprentice
Rating: 75%, 1 votes
hello sir, my name is atul kumar kushwaha from india.i want to open my hp laptop compaq n*6110 for knowledge.plz sir how will open my paptop.plz gv me suggesion..thanyou sir.....
Was this helpful?
Yes
No
Solution #3
posted on Aug 21, 2008
Not Rated)
ebci_s
Rank: Apprentice
Rating: 0%, 0 votes
my systems is allwas asking reset my systems model-nx
Was this helpful?
Yes
No
Solution #4
Not Rated)
rawoo
Rank: Master
Rating: 77%, 20 votes
As it take so long to boot,it may me a problem hardware means the hard disk. Open the laptop and try to well connect the hard disk.Even after that it take time to boot then a problem with the hard disk have to change
Was this helpful?
Yes
No
Solution #5
posted on Jan 23, 2008
Not Rated)
Nubar
Rank: Guru
Rating: 87%, 34 votes
Hi taahir,
I don't think that the solution hughv gave you is the most correct for your problem because it happens before the operating system starts to load.
If it takes 10 minutes to show the HP boot screen, it seems that until then it is trying to detect the hard disk or optical device. It may be a problem with your hard disk or the controller. If possible, try to test with another hard disk to check if it takes the same time until the HP boot screen shows.
Regards
Was this helpful?
Yes
No
Solution #6
Not Rated)
hughv
Rank: Wiz
Rating: 82%, 317 votes
See this article from MS. Pay special attention to the network drives and startup programs issues:
http://www.microsoft.com/windowsxp/using/setup/expert/northrup_restoreperf.mspx
If you got the OS or recovery disks, it might make sense just to reformat and reinstall the OS.
If you didn't get these disks, make an effort to do so.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq nx6110 PC Laptops
Questions and Unsolved Problems for HP Compaq nx6110 PC Laptops
Do you recommend HP Compaq nx6110 PC Laptops?
Answer
Answer
may compaq laptop conut open just stund by what shuld i do
Answer
hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
Answer
Answer
its a fujitsu siemens laptop made in year 2004.
Answer
when pressed down works well
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
