Question about Cell Phones
Sync Manager Problme with Vista with LG CU500
I cant seem to get my sync manager to work with vista and upload contacts, tasks, diary etc...?
i eventually got sync with contacts but only aftre chnaging my com port and even then wont sync properlky and sync other outlook functions !
Can't get the phone (LG TU550) to synchronise. Can't find the com port, it is a USB port.
  • desert storm Feb 11, 2008
    i cant sync my Lgcu500 with my computer (vista ultimate)
  • Anonymous Apr 02, 2008
    can not install drivers for sync music from lg env vx9900 onto vist laptop
  • 48 Answers
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Posted on Jan 24, 2008
I had no problem installing cable and drivers under Vista. HOWEVER, I have total problems trying to use it.
I have to run BitPim in Administrator mode to see the port and even then it doesn't auto-detect the Verizon LG vx8350 phone. After manually setting Phone and Port, BitPim then sees a phone on the port but nothing else. No data, no info, no trasnfers. Logs says "can't transition from none to brew".
Posted on Mar 17, 2008
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Can't sync Toshiba Pocket OC e335 with Outlook 2000 in Vista
I installed outlook 2003 instead of outlook 2000 that came with the pocket pc
Mar 25, 2009 | Toshiba e335 Pocket PC
LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Feb 02, 2009 | LG CU500 Cellular Phone
Programs won't upload to my ipaq 111 classic ppc
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
Dec 08, 2008 | HP iPAQ 111 Classic Pocket PC
SYNC
1300 contact is a lot. If I were you. I will not import all hahaha.
just kidding..
You can try exporting the contact information into Vcards. then store it in your memory card. but ooops. then you need to open each card on your phone 1 by 1.. not good.
May 10, 2008 | LG KU990 Viewty
Driver for lg ku250 phone
its very easy to solve this problem, since vista have new driver management unlike old xp's which need external drivers for all new hardware installed on it, a vista does not.
-- just plug the phone in a data service mode. (on usb connection manager)
-- when vista ask for driver just let the vista search for it.
-- and choose LG xxx modems if asked.
Voila i connected to internet.
for pcsuite like managing sms i dont have solution.
i didnt find problems when accesing my microSD. my laptop recognize it as external drive.
Mar 29, 2008 | LG KG800 Cellular Phone
I can' get my calendar, tasks, etc. to sync to my phone...
call tmobile pda support and get if fixed it takes 5 min heres the number 18009378997
Dec 30, 2007 | T-Mobile Dash Smartphone
T3 sync with Outlook works except for Tasks
A hard reset of my T3 and sync with 'Desktop overwrite HH' on all Outlook conduits seemed to have resolved the problem.
Sep 11, 2005 | Palm Tungsten T3 Handheld
Cell Phones Logo
1,372 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
