Question about GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker replacement Hi, You told me to replace the icemaker with the new one, and this is the best way to fix to problem. Just tell me please if it is easy to do it or I have to ask a technician to do the job. I would like make sure before I buy one. Thanks again. Giap
  • 283 Answers
This is one of the easiest units to replace. Loosen the two screws above the ice mold, swing out and off the fill tube, then disconnect the wiring harness.
Posted on Jan 23, 2008
Water keeps running in the ice maker I replaced the pump and is still doing it
It sounds like your electronic water valve is just stuck open and will need to be replaced, or you could have an icemaker stuck in the fill mode calling for water all the time.
The best way to determine which part is faulty is to just remove the screws mounting the icemaker and then disconnect the wire connection to the icemaker. Turn the water back on and if water still keeps coming in, then you need a new electronic water valve, otherwise just replace the icemaker itself.
Sep 06, 2013 | GE Refrigerator Automatic Ice Maker IM6
Icemaker 106 626133 in 1987 Whirlpool ED22MMXRW sid-by-side
Happy to report that I now have a working icemaker. I had to replace the control module--just replacing the gear was not sufficient. The wiring was slightly different for the new module because it had a side connector instead of one coming out of the lower left corner, but I was able to use front metal plate plus its attachments (motors and switches) of the new to replace the similar parts on the old.
Jul 16, 2012 | Whirlpool Refrigerators
My refrigerator icemaker is not putting ice.I think we have to buy a new icemaker for my unit, we try everithg that was read and nothing work,PLEASE any suggetion?
Hi, Seems your compressor is out of service. You can check the current draw ( by using AC Ampere meter). You can compare the reading with manual book. If the reading is far below, it tell you your compressor is malfunction ( died) and need replacement. Regards,
Dec 15, 2010 | KitchenAid Refrigerators
Icemaker stopped producing ice
Your ice maker can be rebuilt. I would disconnect it from the plug and remove it and carefully take it apart. Be careful not to loose the lever arm spring as you disassemble. Look at it once the screws ar removed under the front cover. It is rare to have a defective new water control valve. But once the ice maker is unplugged you will know because the ice maker is what tells the water to come on once the cube rake reaches home position. Sometimes the thermostat that tell the water on is stuck or the micro switch that tells the heater below the ice maker to remain on causing the same symptoms. So it will be most likely the ice maker and less likely the water control valve. The parts are priced so high it is cheaper to buy new than to buy parts. But I have fixed them without replacing parts. Sometimes the micro-switches just get stuck. What to rebuild it and me help you? Sea Breeze
Apr 11, 2010 | Whirlpool ED2FHEXN Side by Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MSD2756GEW went from hollow ice to no ice. Water dispenser works fine, good pressure, new filter, etc., fill line doesn't appear frozen. Replaced water valve to icemaker. When refrigerator plugged...
I assume the water valve you replaced is the fill valve located within the refigerator.
If so, I suggest that you check the saddle needle valve on your water supply pipe - (generally in the basement). It may have finally clogged up totally from calcium deposits.
Replacing it may resolve the problem. Even if it does not, you've spent less than 10 dollars on it and you've eliminated one of the possible causes.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Icemaker stopped giving ice
The best way to fix this is to replace the ice maker ($50-$95 Bucks).. Unless you have a really fancy set up where the "ice bucket" is located in the door of the freezer.(if so get back with me and I will advise futher... Goodluck!
Dec 20, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
