Question about DVD & Blu-Ray Players
Video recorded on a DVD-R does not want to play in my DVD player
I want to record taped video's onto DVDs to store as the cassette systyms are becoming obsolete. My DVD player does not acknowledge the recording. I am using EasyCap from CORAL and the format is VCD 2.0.
Does SANSUI 212S support and read this format (VCD 2.0) pse.???
Solutions pse?
Many tx
Stephen Theron
  • 75 Answers
Re: Video recorded on a DVD-R does not want to play in my...
Some players will read vcd some won't. also your dvd that your using could be a problem some dvd players don't like some dvd media try tayo yuden's they are the #1 choice for dvd media.
However, try burning the disk into DVD format not VCD this way you will know if it's the media or the video type that your player doesn't like.
Posted on Jan 22, 2008
0 characters
3 Points
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
I have a 8 mm camera connected to the front inputs I have the Insignia plugged in and av2 mode i have a dvdr in the machine I simply hit the record button and nothing happens? I just want to plug my camera...
can't do it that way. you'll need to plug it in to the tv, play it on the tv, and the video output from the tv to the dvd player. make sure you have the correct format of the dvds for that player. some formats of dvds does not work for certain dvd recorders.
let me know what other issues you have
Oct 18, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvds recorded on video to dvd recorder wont play elsewhere
Mosr DVD recorders have a "compatible" setting or require you to "finalise" the disc. Check that is being done.
It's also worth checking that the laptop will play other DVDs sometimes you need a codec.
Jun 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
I Have been trying to dubb VHS tapes to DVD''s. They record alright, but then when I go to play them on another DVD player they won't do I get them to finalize? I have went through the menu and...
--- for some reason this unit does not finalize automatcally.
--- the instructions for finallizing are on page 52 of the owners manual.
--- they are as follows:
1) Press Setup
2) Scroll down, select "Disc Edit", press "OK"
3) Scroll down, select "Finalize", press "OK"
4) Select "Yes", press "OK"
Finalizing will start.
--- have done this operation several times, works Ok.
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Record onto DVD
No. This machine only plays DVDs. You would have to obtain an entirely different machine. One that is a DVD Recorder. This one is a DVD Player + Video Cassette Recorder
Apr 28, 2008 | Zenith XBV243 DVD Player/VCR
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
DVD & Blu-Ray Players Logo
132 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
