Question about Sony Ericsson Walkman® W880i Cellular Phone
W880i cannot save photos to M2 card.
I set the "save photos" to Memory stick and took a photo, it is not saved. When I set the "save photos" to Phone memory, it is working fine.
  • 3 Answers
U should try format ur M2card by pc and then try format it by ur W880i.
Hope it useful
Posted on Jan 22, 2008
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    When i click photos it comes(car, phone, dishw as saving failed..it was alright first..its samsung corby..this problem occured just today
    First check whether the phone is configured for saving the photos to memory card or phone memory. In case it is configured for saving the photos on memory card, change it to save in phone memory and then try saving the photos. In case you are still not able to save the photos, you will have to reset the phone to factory defaults. In case you are able to save the photos in phone memory, try the memory card in another phone, if no go then you will have to format the memory card.
    May 18, 2010 | Cell Phones
    How to get photo's saved to the card, LG VX8350R Receive photo's but can't get them saved onto the card so we can see them on the computer. What am I missing?
    go to bluetooth setting
    change the path of the receiving file
    change it from phone memory to the memory card or stick
    if u r satisfied with my answer pls vote me
    Jan 21, 2010 | Verizon Communications LG VX8350 Cell...
    Transfer internal memory to memory stick. Olympus camera
    Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
    Jan 11, 2010 | Olympus FE-280 Digital Camera
    Messages saving to phone, not memory card
    Have you found out how yet as I would like to know too and I read onew person's review of this phone that it did that.
    Oct 01, 2009 | Sony Ericsson K800i Cellular Phone
    Transfer photos to memory card-Pantech duo
    The only way to clear up phone memory is to connect it to your computer using USB cable that came with your phone. Back up all photos there and save it to your computer. After saving all your photos to your computer, you can simply delete all your photos from your phone memory. Next thing that you need to do is go to phone settings and make sure all captured photos/videos will be saved to your memory card and not on phone memory.
    Jul 26, 2009 | Pantech Duo Smartphone
    Virus in my Memory Card. It is not allowing to save the Photos
    ur memoryt card is been corrupt try to install a new one
    May 07, 2009 | Nokia N72 Cellular Phone
    Transfer of photos on camera without memory card to memory card
    take out the memory card and plug the camera to your computer and it should show that way and save them. hope that helps..
    Apr 05, 2009 | Samsung Digimax A7 Digital Camera
    Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
    it only will show jpeg images no other formats show.
    Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
    Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
    The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
    General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
    Nov 30, 2008 | Computers & Internet
    Lost data
    Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
    Download from the following link ------
    http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
    Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
    For any other help contact me.
    Thanks
    Jul 17, 2008 | SanDisk 1GB Memory Stick M2 Memory Card
    Sony Ericsson Walkman® W880i Cellular Phone Logo
    219 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
