Toshiba 50 inch projection tv picture cuts out
When tv warms up picture is there, after 10-30 minutes picture cuts out. If you rock tv back and forth picture comes back for a while. When working picture shows well.
  • 8,617 Answers
You either have a bad solder cnnection or a loose wire clip. Try the loose wire trick first, then if you cant find it check the circuits for a module not seated or cracked solder joint. If you turn the tv on wait for the picture to go down then take something insulated like a heavy plastic hanger try movng some of the wires and have an assistant observe the tv from the front. If the picture comes back on you have found your problem. Just be careful of the electricty inside the set especially around the flyback and CRTs
Posted on Jan 22, 2008
Have a 5 yr old 50 inch Toshiba projection TV. When turned on, the picture is "scrambled" for 30 minutes and then starts clearing up
Most common problem on Toshiba tv's is the so called nexthyper module thats were your problem is,normaly they have bad ground connections,a tv tech can fix it.
Mar 22, 2010 | Televison & Video
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Projection tv toshiba
my tv did the same thing except it is a 57in hdtv
May 21, 2008 | Toshiba 50H81 50" Rear Projection...
No sound
make sure the external speakers are not turned off
Apr 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
1997 Toshiba 50 inch tv
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Dec 22, 2006 | Toshiba 57H83 57" Rear Projection HDTV
Green Picture
It a picture tube issue or a crt driver issue. Not something a layman can repair unless they have the training as well as the equipment to repair solid state TV sets.
Sep 11, 2006 | Toshiba 50A50 50" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
