PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Acer Travelmate 6291 LCD monitor problem
By coolmanas on Jan 22, 2008
Hi I have a problem with ACER Travelmate 6291 LCD monitor, it shuts down about 10 to 20 seconds after i start it up. Some times it goes blank slowly and some times it suddenly goes blank. I have updated the Display Adpater driver and monitor driver the problem is still there. please help.
Same Problem
Jul 14, 2008
-   I have same problem with Acer LCD AL1715 monitor causing the same problem to me. I have tried the given solution and result is this that graphics card is working fine because monitor is causing the problem with laptop too.
Actually it happens like that when I try to activate monitor by pressing Fn+F5
Keys ( I have Lenovo Ideapad) monitor shows the display for few seconds like 2 or 3 seconds and the it turn off so is there is any detailed solution for this problem.
Thanks for the help.
-   Mudassar007
Jun 06, 2008
-   i also got the same problem..
but mine one got power but the hard disk not running..
the LCD also blank..
-   Guest
Best Solution
posted on Feb 01, 2008
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3791 votes
Your concern is a typical problem with LCD displays/monitors. There could possibly be three (3) reasons why it is behaving as you have posted.
1. Backlight/Inverter problem;
2. LCD panel problem;
3. Video card problem.
You can do initial diagnosis by:
a. connect the laptop to an external monitor. Using the Fn + F? keys, activate the external monitor to be the default display. If it works, you have eliminated the possibility of the video card having a problem. If it likewise did not display anything or blanks out after sometime, then you have just confirmed that it is the video card that is a problem.
If you have ruled out the video card (using above procedure), you can proceed determining if it is an LCD panel problem or backlight/inverter problem.
To determine if it is a backlight/inverter problem, run the laptop normally even without a display. Let it boot and run through its startup sequence even if you can not see anything. Using a flashlight, shine a light obliquely to the face of the LCD display. if you can see some semblance of your desktop albeit dark, then you have just confirmed that it is the backlight/inverter. If even with the aid of a flashlight, the display s completely blank, then it is possible that the LCD display panel is defective. In some cases it is the flexible flat cable that is at fault.
With any of the aforementioned possible problems, opening the unit is required. This would need familiarity with electronic components and circuitry, use of a DVM and perhaps even a soldering iron. Should you not be comfortable doing this, it would probably be to your best advantage to seek the services of a qualifiedly professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
thinkpad t60 battery, any recommandation?
Answer
I am in college, this would be my second computer (my current laptop is too cumbersome to carry), so... (More)
Answer
The HP Pavillio 9700 Laptop computer (less than 2 years old) just shut off while I was using it and... (More)
Answer
All SMART tests suggest no problems. However, when I try to use Gparted to resize Windows partition... (More)
Answer
cant turn on my web cam
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
