Question about Olympus Stylus 710 Digital Camera
Olympus mji 700
When i turn my camera on in the view pictures mode with the memory card in, it comes up with two options:format and power off.if i try to format it comes up with card error message.in shoot mode the camera lens comes out, becomes blurry and a few seconds later returns back into the camera.when i switch it off the same thing happens and the lens pops in and out.also comes up with following error code: D:5f 08 34 02 5e 02 please help when i turn my camera on in the view pictures mode with the memory card in, it comes up .it becomes blurry when i move it to photo mode to take photos and a few seconds later returns back into the camera.when i switch it off the same thing happens and the lens pops in and out.also comes up with following error code: D:5f 08 5e 02 please help
Sameeee problemmmm!
Posted on Oct 19, 2008
Dxg503 in camera mode shows memory full. view mode shows no file. When i try to download to computer it either does not show up or indicates that it is not accessible. using internal memory only
is there anything important in the internal memory? not many pictures can fit there so I suppose probably no?
Format the memory.
Use setup mode to set the camera configurations to suit your personal preferences. Turn the mode dial to SET Mode. And select "Format"
Use the format option to format the camera memory or memory card.
Note: When you format the memory, all data will be deleted.
Now take a few pictures and see if they show up in the view mode or if you are able to get them to the computer. Let me know how that turns out.
Feb 24, 2011 | DXG Technology DXG-503 Digital Camera
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
Hello, How do I format my Lumix camera card? I have a folder on it called "found" that I cannot delete. thanks
Turn on camera, put camera in viewing picture mode. press menu/set, navigate to setup. on page 4 of setup, you have an option to format your memory card.
Jan 03, 2011 | Panasonic Lumix DMC-FZ18K Digital Camera
How do l free up my memory stick after downloading the pictures?
assuming that you are talking about a memory card ..just get into view mode..and on the menu choose storage ..than options and clear memory card ..or ..just again in view mode..choose a picture and options and when you try to delete will ask for multiple delete ...select them all and delete ..or just insert the card into a card reader and when it shows in the my computer folder open it ..select all pictures and than press delete ..
the fastest way though is to simple select in the main menu the storage ...in there select card ..and on options format card ...this will erase all on it ..and format it in the same time for best performance in the device ..
Jun 16, 2010 | Olympus FE-310 Digital Camera
Inserted a memory card and it says memory card error
Is it a new 4GB memory card? If so that might be your problem. The card would likely be an SDHC card, and your camera was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
But if the card is less than 2GB, it could have become corrupted. In this case you could try formatting the card in the camera to see if this would rejuvenate it. This will also erase the card. See this post if you wish to first recover those pictures.
Finally, if this is occurring with multiple cards, and is also saying "card locked" even though the tiny slide switch is in the unlocked position, then see this post for a possible remedy.
Aug 04, 2009 | Canon PowerShot A520 Digital Camera
Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 02, 2009 | Olympus Stylus 790SW Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Sep 02, 2007 | Olympus MJU 400 Digital Camera
I cant see my pictures
Can you check the card by a car reader in the computer- or some one else computer? Failing that Format the card in the camera then have a try Come back let me know how you get on
Jul 21, 2007 | Olympus FE-230 Digital Camera
Olympus Stylus 710 Digital Camera Logo
140 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
