Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Not detecting that hard disk drive is give small beep sound and one time show the partitions and another not showing the disk drives whtat is the hard disk problem and how to solve these problems? please send the mail my mail address thanking u regards visweswararao hardware eng.Hyd viskar2nag@gmail.com
    New Friend:
Password is not working. i need to open it without formatting, because i have lot of important files inside it.
last two years i work with it smoothly, suddenly when i write down my password it shows invalid password.
please please give me the solution
thanks
shuvo
Posted on Aug 28, 2013
    Problem Solver:
  • 23 Answers
Sounds like a loose power cord...
-Damian
Posted on Jun 12, 2008
External Hard disk is not detecting on my desktop PC
Try a different usb port. Maybe a 1TB external hd is too big for your old computer to recognize. Old computers cannot handle a drive that large.
Jun 08, 2012 | Computers & Internet
My maxtor external hard drive gives a beep sound when I plug it to my computer. The computer says "a new external hard is added to your compute"r but when I click on MY COMPUTER, it doen't...
1) click start
2) right click on "computer" or "my computer"
3) click manage
4) IF you get a user account control popup click yes
5) double click on storage
6) double click on disk management
7) identify your disk, it should be empty and most likely named "disk 1" or maxtor drive or something
8) right click on it and select format (quick format, default allocation size, NTFS)
9) voila!
-Luke
Jul 21, 2011 | Maxtor Hard Drive
How to make a potission on new hard drive
If you running win XP, here is a small video that shows you how:
http://www.youtube.com/watch?v=bwNLNYhTaEk
Sorry for the bad sound.
Its almost the same in vista.
Hope this was helpfull.
Mar 12, 2011 | Dell Computers & Internet
I have an external hard drive made by Gigaware. When plugging it in, the computer recognizes it as mass storage device but will not show up in My Computer. The external drive is on and spinning. Any...
If you have not used the external hard drive before, you will have to go into your drive management and initialize your drive and possibly format it. The fact that your computer recognizes it is a good sign. It means that the external drive is working properly and the computer recognizes that the external drive is there. I have an short paper I have written describing how to use the drive management utility in windows. It is too long to post here. I can either post part of it or you can give me your email and I will send it as a MS word attachment so you can have the entire paper.
I hope you find this helpful Brian
Here is the part I can post here:
Using Disk Management Utility
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken.
Dec 25, 2010 | Computers & Internet
My western digital dosent get detected, whenever i connect the device a new hardware found sound comes and nothing comes in my computer, i tried restarting nd olso tried to connect the device on other...
sometimes drives need to be initiallized when they are connected I will give you instructions to use the Manage Feature of windows to manage your drives. The instructions are as below:
If you cannot see the drive using the disk management utility, then you need to check to be sure the drive is not malfunctioning and also check your connection cable to be sure it is not the problem.
I hope this is helpful!!
Brian
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Dec 23, 2010 | Western Digital 320GB MyBook External USB...
Drive only reports 56gb to partition - missing 100gb! How do I access the remaining space?
Click Start
Right-mouse click "My Computer".
Click "Manage".
Expand the "Storage" part of the tree.
Click "Disk Management".
View the diagram for your disk-drive.
Does it show the 56GB partition, followed by 100GB of "unallocated" space,
or does it show one (approximately) 160GB partition?
If the former, backup all the files in the partition (copy to an external disk-drive, or copied to DVD-recordable disks, or to another computer).
Then, use "Disk Management" to delete that "small" partition, and to define a new partition that "spans" the entire volume, and to initialize the partition.
Then, copy the "saved" files back onto the drive.
Dec 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Cannot access hard drive, USB port detects it, but does not access
You can verify what drive has been detected by your Operating System, which I assume is Windows of some sort by going to: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions.
I order to use any partitions in your new drive, you will need to assign a drive letter to each new partition.
If you have a brand new drive that is completely unformatted, then you will need, also via the context menu, Create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions.
Hope it helps: let me know how you go!
Below is example of Disk Management display showing my external USB 300GB drive with _EXT disks & displayed context menu:
Jan 02, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Hard disk failure..
YUP! this can be fixed. if u r runnig on XP the best software for this would be Partition Magic or if u r on Vista then Paragon Partition manager
i hope i helped!
Oct 22, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
My Samsung HDD SP0802N 80 GB PATA says read error and not booting
dear suresh
just trying using hdd utility like partition magic or with disk management in window
but i supposed to fixed it in another pc , you can partition it with two or three partition
after that youcan format it
oke
cropp
Mar 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
153 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
