Question about HP Pavilion dv1000 Notebook
HP DV1000 Hello, I have an HP1000 the lap top screen comes on SOME TIME. Some time it does not. Other time if I shake it it works BUT on the lower left hand corner it gets very hot and it forms a black spot - that very hot to touch. any advise.
  • 1 more comment
  • goodsports Jan 30, 2008
    I have the same computer - and the screen goes dark (but can barely see the screen - as if through a filter).  If I put it to sleep and turn it back on the screen returns and may stay on a long time, or not....  It seems to be affected by movement at times, and at other times not...  Is it an inverter board or backlight problem.  Geek Squad seems to be certain it is a backlight problem fixed at a cost of 350-400.  Any ideas.
  • Anonymous Aug 20, 2008
    I have the same LCD screen problem, goes on and off when I press the lid close switch button though the screen's color is fine. At first, I thought it is the inverter since the screen is very dull. I already replaced the inverter but still having the same problem. It seems my lid close switch is the problem, it's unsteady. Can you please tell me how to fix the lid close switch?
    Thanks in advance for help....
    LBS
  • freebird9747 Mar 07, 2009
    dv1000 the screen goes dark if you press the screen switch it comes back on
    Problem Solver:
  • 12 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Http://cgi.ebay.com/LCD-inverter-fit-HP-Compaq-V2000-M2000-DV1000-ZE2000_W0QQitemZ270242429656QQihZ017QQcategoryZ31569QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
backlight inverter
Posted on Jun 04, 2008
I have the same computer. I changed the bulb and iverter board and have had no luck. You can get the parts for under $50 total. If you can install themm yourself.
Posted on Mar 06, 2008
Hello tom19511, I could not find any thing when i search in the above file under inverter board of back light?
How can i be certain that it is the inverter board? How can i get an Inverter board for this computer? Do you have a number i can call you on?
-Jitu
Posted on Jan 23, 2008
    Genius:
  • 1,601 Answers
Jutic, the problem is most likely the inverter board. Here is your manual.You can see what it takes to replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Posted on Jan 22, 2008
HP DV1000 screen too dim
The 4 most common problems with dim lcd's on a laptop are boken screens, bad power inverter, bad florescent bulbs or a broken cable.
You can test the power inverter with a meter.
There should be 2 bulbs. If your screen is dim and your inverter is good and you can still make out what is on the screen, you probably have a bad bulb. If you can't determine which bulb is bad you'll have to replace both.
In my opinion, the easiest way to handle this is to replace the whole screen. Yes, it's more exspensive, but consider that it is most likely to fix your problem. A replacement screen comes with the power inverter, both bulbs, and the cable; already assembled and ready to install.
Mar 06, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Blue screen with HP Logo is frozen on my lap top screen
try contrl alt del at same time hold for 5 sec if that does not work take batt out hope this helps
Oct 16, 2009 | HP Pavilion dv9000z Notebook
I used The FN and F5 key and it worked
Go to the point where you have a stable picture even if it is huge. Right click on an empty space on the desktop and scroll down to properties. Click on settings and increase the resolution a little at a time hitting apply and checking the display as you go. Keep hitting ok to the display settings if you like them. Find the resolution and display size that suites you.
Sep 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
My laptop shuts off after the windows logo appears
I had the same problem. come to find out it was the back light on my lap top.have that checked out and let me know if that was helpful or not.
Apr 13, 2009 | HP Pavilion dv1000 Notebook
Thin Red Line on Left Side of HP Pavilion DV2000 Lap Top Screen
Majority of time it's the lcd that has a problem which creates the red line, otherwise it's the GPU (video processor).
Try hooking up your computer to an external monitor. If you see the line on the external chances are it's the lcd.
This method of testing isn't fool proof but either way the problem is hardware related.
Let me know if you have any other questions.
Mar 04, 2009 | HP Pavilion dv2000t Notebook
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
I bought two games for my new computor. one will load but will not come up to play. the other will not load at all. i did every thing it said to do. went to computor clicked on set up and the game will not...
The game could be NOT for your system.
If your system is for examble: Windows_XP 533 mhz 35 MB RAM
The GAME: Win_xp 1.2 Ghz 500 MB RAM or a different o/s [operating system] lets say Playstation, or XBOX ??
Look on the side of the box to see what the games call for>
Apr 15, 2008 | HP Pavilion dv1000 Notebook
Lap top hp notebook series
One of 3 things have gone bad, either the hard drive and/or motherboard and/or the drive ribbon cable. First try removing the hard drive and reinstall the drive and try booting the laptop, if it still does the same thing, then it is time to send to the repair center. BPCS
Dec 02, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
2,694 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
