Question about Motorola Mobility RAZR V3i Cellular Phone
Ghost memory!!!!help!!! everytime i erase all the music and pictures and videos in the memory card of my motorola v3i, it all come back to the memory card like a ghost...help!!!what should i do?
  • makoi Jan 22, 2008
    help!!!ghost in my memory!!!!...card!!!!
    Sergeant:
    Champion:
  • 241 Answers
Take out the memory card - connect it to your computer - do a complete format.
before replacing back into the phone, check the phone to make sure the photos etc aren't on the phone too.
Posted on Jan 23, 2008
How to reformat the phone?
formatting your phone will set back your mobile to its original setting.
to be able to do this,just go to settings > initial set-up > master reset
* If you choose master reset - this will just reset your setting to default.
* if you choose master clear - this will erase all content of your mobile including your contacts,messages etc. be sure to back up your files first before doing this method.
* if ask for the code
default unlock code is - 1234
default security code - 00000000
good luck.
Jun 18, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Krave Camera Not Working
mine had the same problem.
go into memory under settings and (if you have a card) move some pictures/videos/music/sounds to the card from the phone memory.
if you don't have a card, try deleting a few pictures/videos/music/sounds from your phone memory.
hope this helps!
Jan 04, 2010 | Motorola Mobility Krave™ ZN4 Cell Phone
Ihave a motorola v3. I cannot access the pictures
look in settings and look for the selection for internal or memory card...
Aug 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
4g sandisk (wont format)
I have heard of cases of SD cards just giving up the ghost and not working. If it is only 3 months old I suggest you take it back to the place you bought it
May 28, 2009 | SanDisk 4GB microSD High Capacity Memory...
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Storing text messages
This is because the Razr stores texts and emails dynamically according to message size and physical memory available. To balance it out, you would have to delete some outbox messages to store more inbox messages and vice versa. The amount of pictures, ringtones, incoming/outgoing calls, emails, texts, and videos all are drawn off the physical memory of the Razr. The device does not have dedicated application memory so everything is taken off the small amount of memory you are given. Newer Razr's such as the V3m for Sprint offer Memory Cards to supplement additional memory. Your device is equipped with a microSD card slot and you can save your music, pictures, and videos to the card and leave the additional phone memory to texts and application memory. You may not be able to save that much more if you move the pictures and music, but you can save more than if you didnt have a memory card. When reaching the maximum limit of memory the phone will tell you that you need to delete some files before continuing to do anything on the phone.
Dec 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Things i dont know in using motorola v3i
for erasing messages you should click the button that is in the middle, at the top of all buttons of the phone.. then you will see the options you can select, between them, there is "erase", you can choose to erase them all, or just the message you were reading..
don't know is themes can be dowloaded.
for the pictures it is quite the same, if you go to options, using the same button, then you can choose something like "use different memory device" and if you choose that, you can choose between the intern memory of the phone and the memory card you are using..
I hope this was a bit helpful.. Can you rate this solution please??
Dec 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Hoe can i erase most of the items that was pre installed in the cellphone?
You can delete all the phone's mem..phonebook, pix, ringtones, flix, etc...by going into Menu-settings--initial settings, and scroll to see reset and/or erase/clear...the security code should be 000000. As for your downloads, you can tell where you want the file/s to be located..go to Menu-settings or tools-then memory...there should be a option there for storage loaction...phone or card etc....
best of luck....
Jul 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Music downloaded on memory card put in razr V3i wrong format
i had the same prob previously so i checked the ones that usually have an error on it. i started downloading or picking versions of of the songs that has 128-192kps ratebit.. i see to it that the songs that i would be downloading are within this range, try doing this, my memory card is 512MB and i have 63 songs in the phone as of the moment.
Jul 10, 2008 | Motorola Mobility RAZR V3i Cellular Phone
It's all bout the video of motorola v3i
yes the video is slow in V3i i think if you use the 2 gb memory card that might hep you and always save the video in memory card if you like to know more please contact me
Jan 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
