Question about Samsung 710V 17" LCD Monitor
Optimum mode problem
In the middle of work moniter suddenely goes off displaying message not optimum mode selected "1280x1204 in 60Hz" after that it also displays a ? in the middle of an square
  • Anonymous Jan 30, 2008
    The same thing happens with my samsung SM 710v. Please, advise something.
Same here..... :(
Posted on Feb 10, 2008
6ya staff
SOURCE:
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Jun 29, 2011 | Computers & Internet
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
Jun 05, 2011 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
My monitor has a message floating up and down saying not optimum mode recommended mode 1280x1024 60Hz what do i do
dear dalton,
1.right click on desktop.select properties and click it.
2.then select settings tab on top.
3.there u can see the screen resolution slider bar. there u can select the optimum mode for ur monitor.
thanks,
Sep 30, 2008 | Computers & Internet
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Computer moniter
Press F8 during startup to show the boot options. Boot to VGA mode (if available) or safe mode and change your resolution in windows to the recommended 1280X1080. To do this in XP just right click on the desktop and select 'properties', click on the right-most tab and move the slider.
In Vista this would be right-click desktop, select 'personalise', click 'display settings' and move slider.
Hope this helps,
erch.
Mar 15, 2008 | Computers & Internet
Samsung 710V 17" LCD Monitor Logo
220 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
