Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Bulb firing, won't stay on
Hello, I have been reading through all these problems and I think I either have a problem with the ballast or light engine.. not sure though. Can someone offer me some assistance?
When I do the system test I receive the error code of 34. I removed the cover from the back and when I turn on the TV I can see the bulb light up for about 5 seconds and then it turns off. The TV(fans) will stay on for about a minute and then the TV turns off and the Lamp Light will turn on and stay lit Yellow. I can not turn on the TV again unless I reset or unplug it from the wall and start over again.
Is there something else I can test to verify what the problem is?
Thanks in advance.
  • 3 more comments
  • smithnl78 Jan 22, 2008
    Are you talking about the dust filter on the left side of the TV or is there a separate air filter? I have cleaned that dust filter a few times and that does not seem to make a difference.
    I have tried replacing the bulb with a new one, I get the exact same results. I have cleaned that spongy dust filter a couple times with no change. Is there some other place I can check the filter unit to clean it? I don't have the service manual so not exactly sure how to get to anything.
    I would like some help finding the service manual. I have been looking myself but I guess not in the right places. If you do find it you can email it to me at
  • zeebrew Jan 24, 2008
    I am having the same exact problem. Replaced with brand new bulb. Bulb fires on for about 5 seconds and fans run until red light comes on. I also have cleaned out left side panel filter. Where is this other filter you refer to that needs to be cleaned? I purchased this set in 1/2005 and I am now on my 3rd $250 bulb. I do hear a bit of a humming noise I beleive from the cooling fan under lamp. I also did not receive any warning to a blinking orange light. One day it was working and the next day I had a fixed red light. Any comments would be appreciated.
  • smithnl78 Jan 27, 2008
    I fixed mine by replacing the 2 capacitors on the power board. I couldn't find any 10v 3300uF capacitors in town and replaced them with 25v 3300uF instead. I decided against replacing the 4 on the DM board because they looked fine. I usually go with the saying if it ain't broke don't fix it. I figure if something else goes wrong I will know to look at the DM board first now.
    Thanks for all the help everyone.
the last guy is correct. the 3300Uf caps, located side by side next to each other on the main power supply board go bad, causing the sensor that detects light coming from the lamp starting up, to not have the 5 volts needed to sense the " flash" from the lamp.
the caps will usually be bulging at their tops, with brown electrolyte oozing from them.
change them, reset by plugging the tv back in, and your problem is fixed.
I shouldn't be telling you this, (i'm a tv tech) I charge $350 to fix this problem.
I figure anyone who is intelligent enough to repair their own set, deserves a break now and then
David klebs
Posted on Jan 28, 2008
I had the EXACT problem with my 2.5 year old WD-52525. After reading tons of comments on this site, i came accross a DM Repair solution by a guy named Techman (sorry, i can't find the link anymore). The problem that causes the bulb to only fire for 10 seconds and turn off is due to 2 capacitors on the power board, NOT a faulty bulb, The 2 3300uF 10v capacitors are located on the main powerboard of the TV. There are a total of 4 boards sandwitched together making up the chassis. Techman's article explains to replace a set of 4 1000uF 16v capacitors on the DM board that affect the picture. Although those capacitors may need to be replaced as well, the 3:4 bulb red light problem is from the 3300uF 10v caps. I would suggest getting the service manual from to see how to remove the chassis and get to the boards. Then refer to Techman's instructions on how to replace Capacitors on DM boards. Replace the 2 3300uF 10v on the power board and also all of the 1000uF 16v capacitors on the rest of the boards (i replaced these as well just in case they were bad) and your problem will most likely be fixed. I have never soldered before and know nothing about capacitors but with some patience and Techman's instructions, i replaced the capacitors, put the tv back together and to my suprise, it fired right up and has been properly ever since. The capacitors, a desoldering iron and a regular soldering iron from Radio Shack cost me a total of $30 to fix my TV. The authorized Mits repair man i had out to look at my TV before i tried to fix myself said that i need a new ballast and/or light engine and quoted me anywhere from $1,000 to 1,800 to fix the problem. Thanks to hours of research on this site and a few hours taking apart my tv and replacing the capacitors myself, i saved a ton of money.
Posted on Jan 27, 2008
  • 96 Answers
Hi. It does sound like it is the filter unit, I've seen this before, I also seen the bulb not able to turn fully on, defectibe bulb.
I hope this help
Posted on Jan 22, 2008
  • Mitsubishi Master
  • 8,617 Answers
Try to clean the air filter it soubds as if that is the problem. Then try it aain. If you need further assistance let me know.
  • Sonny Berry
    Sonny Berry Jan 22, 2008
    You could have a defective bulb, Ballast or power supply. You will pobaly need the service manual so you dont end up buying parts you dont need. If you would like I will try to find a source for the maual for your model. let me know if I can help you further.
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
My yard light, I think its a mercury vapor light? will go off randomly at night and come back on after about 30 seconds continuously. Any suggestions?
Check whether it is self ballast, if it is self-ballasted, so the ballast is integrated with bulb itself, so you can replace it with a new bulb, it can be self-ballasted mercury vapor bulb or regular energy saving bulb., if it is mercury bulb need work with ballast, from your description, the capacitor should be replaced, which is a little bit complicated, you should check it with electrician, or you can do it carefully after you read some documents.
Safety Tips: Turn power off at any time before you start to repair any electric appliance or lighting equipment.
The following is some reference for mercury bulbs and its associcated ballast.
Good Luck
Nov 03, 2013 | Home
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX HPS and MH electronic ballasts can be light up
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Hey i have a panasonic Plasma tv (model: TH-42PW5 ). When i press the button to turn the tv on the green light comes on and stays lit, but there is no picture - the screen is dark. What could this be?
The problem is either from the lamp or ballast. Have you ever changed the lamp/bulb of your TV?
When the LED shows green, it means it is a lamp problem.
The ballast helps to ignite the lamp and make it function well. So you might have to replace the ballast also.
Good luck.
Mar 18, 2011 | Televison & Video
Set is an LG DLP model RU 52SZ51D. Set sometimes needs to power cycle 20 or more times to fire up. Other times 1 or 2. The red led turns to amber and flashes approx 55 times and then turns to red and...
I need to know titles of lights that blinks on tv while it trying to power up. There are Power, Lamp and Temp lights, let me know what light blinks, this will help me to diagnose the problem as I hate to guess like try this and try that.
Aug 26, 2010 | Televison & Video
I turn tv light comes on but i get no picture or audio....then light indicator blinks red
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
I have an 04 prius that had same problem on passenger side...put in a new Philipps bulb I bought on ebay, still flickered...turned out to be the contacts on the D2R ignitor cable (the cable that plugs into the back of the bulb). They were noticeably burnt/oxidized. I cleaned them up with a small grinding attachment on a dremel tool. Worked like a charm, no more problems.
Apr 08, 2009 | 2007 Toyota Prius
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Sep 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
436 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
