Question about SanDisk Sansa e250 MP3 Player
Mine wont even turn on
I was in the middle of removing some tracks from my device, and somewhere in the process of me removing it from my computers (i use a laptop and desktop, it just went blank. Now i cant turn it on, and I read somewhere on there holding the rec. and menu button will reset it but that didnt help. Im not good with repairs so I would rather not have to take it apart...
Any Suggestions?
  • cman101 May 17, 2008
    ive tried to turn on my mp3 but failed numorus times. if i put it into the usb drive it works. iu then try to disconect it and it shuts off. i charged it for over 2 hours.
I don't know either, it froze on me,shut off, then wont turn on. kind of annoying, i need help because i don't want my parents to feel bad about that gift.
Posted on Jan 22, 2008
Didn't get any instructions. i need a manual
This device should appear as a USB mass storage device when you plug it into a computer (windows, mac or linux should work).
Once it's visible, simply drag (or otherwise copy) your music into it. Then unmount it (eg. "remove safely" on Windows). Removing files is basically the same process: just delete the tracks you see on it as required.
When it has music loaded into it, set the switch on the side to the "on" position. It should start playing immediately. The main button panel should be self-explanatory: there's a play button in the middle, skip forward and back on either side, and volume up/down above and below. There's no way to mess it up, so just play with it until you get the hang of it.
Tracks are played in the order in which they were loaded onto the device, unless you use a utility to sort them. Unlike the iPod Shuffle (which this appears to be a clone of) this device does NOT play in random order. Your friendly neighbourhood hacker will be able to use a utility (such as "fatsort") to reorganize the playing order.
This device sometimes loses track of where it's supposed to be, and just starts at the first track again. Annoying, but what do you expect for cheap?
Aug 28, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Jensen SMPV-2GBUB wont turn on or charge
How to get the Jensen mp3 to charge - model smpv-2gbub,
transparent-pixel._v42752373_.gifIgnore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1.When computer is on and at windows screen, attach cable from computerto mp3player with mp3 turned player off. It will immediately show you aconnect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3.Now turn the mp3 player on by switching the button on the right side ofthe device to the on position. It will suddenly show you it's charging- the battery on the front of the mp3 player will have a signal pulsingthrough it.
4. It will turn off after one minute. It's literallyhalf charged now. Strange I know. Repeat from step 1 and it will fullycharged.
If it doesn't fully charge after it turns itself offafter 1 minute the 2nd time, then repeat steps from 1, one more time,but this time when it turns itself off after a minute, still leave itconnected to the computer for 10 mins even though it looks like it'soff. Then disconnect it physically from computer, turn it on with theon button on the right side, press the left side middle button twiceand look at the battery on the screen - it should be fully charged now.
Jan 30, 2010 | Jensen Audio Players & Recorders
My ds keeps freezing!
try cleaning where the gameboy cartrige is if that doesnt work leave it for a day or two. DONT WORRY. MINE DID THE SAME THING
Jan 08, 2009 | Nintendo DS Console
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Cable has broken out of thier holders where they attach to the window what has to be replaced can i jerry rig it
I'm in the same boat. We had the rear window replaced by the shop a couple of months ago, but the driver side window is doing the same thing. I don't want to spend another $250 if I can do it myself.
Jul 27, 2008 | 1994 Mercury Grand Marquis
Bad track, its frozen and it wont respond to the computer
bad track it gets freezed not able to connect to my PC not able to switch off help me
Apr 29, 2008 | Audio Players & Recorders
When i turn on my nw-e107 it just simply turn on and off!
try formatting through the mp3 player. go to menu -> advanced -> format -> yes.
Dec 07, 2007 | Sony NW-E107 MP3 Player
Unable to shut down device - "Bad Track" error msg
You may need to hold down the button for up to 30 seconds in order for your MP3 player to turn off.
Sep 17, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
