HP Pavilion dv6000 laptop wont boot up
My nephew's hp pavilion dv6000 laptop won't bootup. It gets power, all lights power up and the cd rom ejects, but it just has a blank screen. The blue light that looks like a box above the mouse pad just stays orange. I have tried releasing the battery and placing back in, tried without battery and just using the power cord, and have held down the power button down for 10 to 30 seconds hoping that would reset it. Nothing seems to work. It was working fine until I tried to stop some programs from working in the back ground by using msconfig. When it said I had to reboot, that's when it stoped working. Can you please help!
Thank you
  • 3 more comments
  • rgmz3918 Jan 29, 2008
    Thank for your advice. I didn't have to do all those steps. I was able to fix the problem by removing the memory module and placing it back in. After I did that, it booted right back up and everything is good.
    Thanks
  • Anonymous Jun 12, 2008
    after apprearing av F2 or F 12,
  • mbakitt Aug 29, 2008
    my hp pavillion dv6000 powers but there is no display at all,i tried taking out the memory and hdd but still does not display still.
    buck
  • charlesdoo Sep 09, 2008
    my hp pavillion tx2000 powers but there is no display at all,i tried taking out the memory and hdd but still does not display still.
  • kalumichael Sep 25, 2008
    I have a pavillion dv6000 the optional, without camera. I shut down properly but when i put it on the next day the power light comes up, the cdrom works, but no display, even when i tried it with an external monitor. I removed the memory and hard drive and put them back and it still gives the same problem. Please what do i do? should i remove the cmos battery and see if it will work, if yes where do i locate the cmos battery?
    Thank you.
    Michael
    Sniper:
  • 58 Answers
Try this first, Press the F8 key a couple of times when starting up. This should get you into "safe mode" and you'll need to go into the Help and Support section and do a system restore back to a restore point. If that doesn't work, then you might need to do this: 1. Press F11 on the keyboard immediately while the computer is starting up. The HP Backup and Recovery Manager window will appear.
2. If the Recovery Manager can access the hard drive it displays a prompt to backup up your user files before continuing the recovery. If it cannot access the hard drive to fix the system errors, the Recovery Manager starts recovering the hard drive to its original condition.
Of course doing the F11 process will wipe out all your files and reset the drive back to the factory settings.
Posted on Jan 22, 2008
    Problem Solver:
  • 15 Answers
It looks to me that you guys had the bad luck to get into the "Enhanced Warranty" models. I send those frequently for repair. Please visit this site at Hp.com check your serial number and I bet your laptop will be there. The warranty was extended for these models and your laptop will be fixed without any cost.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Good Luck!
Posted on Sep 28, 2008
    Scholar:
  • 61 Answers
The motherboards used in dv laptops (also certain compaq presario models, and acer aspire models) have a defective cooling design. This applies to intel and amd based boards-the gpu (graphics processor) overheats and the solder loses connection with the board. Nvidia addressed this issue and said they believed it was due to a bad material used in the manufacturing of the dye, but that has nothing to do with the connection to the board so obviously they have no clue what they are talking about. To fix this issue, the bga needs to be resoldered (reflow)-there are several methods to this. The easiest method I have seen is to tape all vents to prevent airflow, wrap in a blanket several times, and let run for an hour. Make sure you let it cool for an hour or so afterward. I have read several posts expressing success using this method, none have indicated failure. The actual process involves COMPLETE disassembly of the M/B, insulating the board around the chip, and SLOWLY heating the chip to 270 C using a heat gun (use infra-red thermometer, do not exceed temp). Then letting chip cool slowly, still heating to slow the cooling process. All-in-all, it takes about an hour to perform the reflow (without counting disassembly/assembly).
Posted on Feb 16, 2010
  • 1 more comment
  • chris bean
    chris bean Feb 17, 2010
    I wrote 270 degrees celsius for the max temp, it is in fact 220 degrees. Should be slowly brought between 150-180 degrees celsius (at 2-3 degrees per second) for 1 minute to allow the flux to work, then brought between 183-220 degrees celsius for 1-2 minutes for the solder to reflow, then slowly brought back down, at less than 6 degrees per second.
  • renanpos Jan 19, 2011
    I was able to solve de problem without having to open the laptop. I used a hair-dryer for it.
    Remove the battery, and force the spring, so that a little hole appears, near the edge of the battery compartment. If you check out the videos on youtube, where guys open every thing, you can see that the video chip gets very near this area.
    I applied the hair-dryer for about 10 min, pointing this hole inside the battery compartment (remove hd and ram memory before doind this, becaus things get really hot).
    I would suggest use foil to protect the plastic external areas, to avoid melting troubles.
    Worked for me ... but I'd better backup every thing and sell it in short time ...
  • demons427 Feb 07, 2011
    I decided to give •renanpos hair dryer through the battery opening a try,
    Nothing to lose I figured - my DV6000 was totally dead. Ten minutes of heat and it worked perfectly. I would never have believed it. Only thing I would add is to double insulate or tin foil the battery compartment - the heat can distort the plastic.
    •renanpos•19 days ago
    I was able to solve de problem without having to open the laptop. I used a hair-dryer for it. Remove the battery, and force the spring, so that a little hole appears, near the edge of the battery compartment. If you check out the videos on youtube, where guys open every thing, you can see that the video chip gets very near this area. I applied the hair-dryer for about 10 min, pointing this hole inside the battery compartment (remove hd and ram memory before doind this, becaus things get really hot). I would suggest use foil to protect the plastic external areas, to avoid melting troubles. Worked for me ... but I'd better backup every thing and sell it in short time ...
If my dv6000 board is bad what do i do, can it be replaced?
Mike Kalu
Posted on Oct 02, 2008
Hi sir what you have just done when you tried to stop that program in the background you probably stopped the wrong file with msconfig. You must of stopped of stopped a vital system file which probably helps the computer to function with startup and suchlike. What program were you trying to stop? The only real solution would be if you can't start it up at all would be to get a CD-ROM with a factory image of the computer image on it and pop it in and restore the computer. The unfortuanted thing with this is tho your going to lose all of your files. If thats an issue then you have to try to get it to boot because you can definetly just restore once it boots and everything will be fine. Call HP and ask about this too because if there is a CD-Rom(Which there prob is) that you could just insert to restore all the software without erasing user files because obviously what you deleted was a system file that you don't actually use on a daily basis but the computer needs to function. Now I just realized that you already fixed it and the my previous words i just realized were pointless but by you removing the memory module you probably reset the files that handle memory exchange and transport so you must of deleted a file that helped a program run in the background but it was actually a system program and it deleted the files all together to let anything ever run in the background. Hope I explained something useful hahaha;)
Posted on Jan 02, 2011
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
My CD/DVD ROM IS NOT WORKING WHAT COULD
Does it seem to be missing altogether? There is a Microsoft Fix It page here: http://support.microsoft.com/gp/cd_dvd_drive_problems
Click on the "Run Now" button.
Apr 22, 2010 | HP Pavilion dv6000z Notebook
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
Sep 16, 2009 | HP Pavilion TX2000Z Notebook
WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
May 22, 2009 | HP Pavilion zd8000 Notebook
Does not work, meaning does not read anything.
may be lens does not work and its life is end.or clearly tell me your problem what show this when you insert cd in cd rom
May 06, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
25,266 people viewed this question
Alun Cox
David Payne
David Payne
