ViewSonic PJ551 Multimedia Projector Logo
Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ghost image in different color from main image - text appears "doubled"
Anonymous
Level 3:
  • Master 1,305 Answers
  • Posted on Dec 16, 2009
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
596432
Points
4327
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
2helpful
2answers
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
2answers
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
2helpful
2answers
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Double images with red halo outlines
Sounds like your describing convergence ICs. They cost about 10.00 each and you will need to replace both of them. And possibly the resistors that power them total cost under 30 dollars if you do he soldering yourself. Hope this helps.
Top ViewSonic Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
