Question about Nokia 3110 Cellular Phone
Battery not charging
Could someone let me know why the battery is not charging even though the charge indicator indicates charging The nokia centers have not been of much help
where can i get the technical service manual for Nokia 3110C
  • Anonymous Feb 10, 2008
    my mate had a similar problem, battery charge ran down within a day.
    A replacement battery did not fix the problem.
    Orange then replaced the phone.
  • 4,102 Answers
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Posted on Jan 22, 2008
In my phone the charge reduce very quickly
Posted on Nov 16, 2008
6ya staff
SOURCE:
How do I know if my kindle fire is charging when I plug it in. There is no light indication that tell me if it is. Even tho it has been plugged in I have less than 5% charge and it shuts off.
There should be a charge indicator at the bottom (yellow?). Shows green when charged. From your description, it sounds as though the battery is shot.
Oct 07, 2016 | Amazon Kindle Fire HD 8.9"
NOKIA C1 01 PHONE BATTERY LOW PROBLEM WHEN BATTERY IS FULL CHARGE.
Hi Please clean the Center terminal of the battery as well as the battery connector of the phone.That's all you have to do and this is the first aid.Sometimes battery low indicates when the center terminal has short/ not contact to the phone properly. Thanks for visiting fixya...Good luck
Sep 13, 2011 | Nokia C101 Cell Phone
K660i not charging the battery though indicator says charging
the the charger terminal, but the first thing is try to replace another battery
Aug 07, 2009 | Sony Ericsson K660i Cellular Phone
Battery does not charge and does not provide backup power
change the batterry immediately...it will surely damage ur laptop
Apr 18, 2009 | Computers & Internet
Nokia N95 don't switch on.
Only Hope you have is to take it to a Nokia service center, they will probably charge you for the repair as it is a none warranty fault and any data that was stored on the fone will be lost. Go to the Nokia web site to find your nearest service center
Feb 01, 2009 | Nokia N95 Cellular Phone
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Battery charge question
in this phone when the battery is fully charged the running battery indicators stop at full position. U must charge every phones battery a maximum of 2 hours b'coz charging more than it reduces battery life and if the battery is not fully charged in 2 hours u must charge it after 20 minutes again
May 20, 2008 | Nokia 2610 Cellular Phone
My new sony ericson w850i is having to be charged every other day even though sometimes I haven't used it for more than 1 or 2 text messages,when I plug the charger in (the one that came with it in the...
optimise charging means that it is charging.. try leaving it to charge for an hour or two. if it still doesn't work, then you bring it to a service center.
Apr 27, 2008 | Cell Phones
Nokia 3110 Cellular Phone Logo
363 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
