Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh Aficio 1515
Paper tray is full but load paper tray light is on
  • Gushdv Jan 24, 2008
    My printer is Ricoh Aficio 1515. The problem
    I am having is that I broke a flimsy plastic part that makes contact with the paper in the paper tray. The function of this piece is to detect whether there is paper in
    the tray or not. Since it is broken, the printer is showing "out of paper" even though the tray is full with paper. as a result, the printer does not print. Other than replacing this broken part, how do I permanently disale the function of this part? Since it seems so unnecessary.
  • Ricoh Master
  • 1,113 Answers
Do you really want to bypass this mechanism?
I don't think it is a good idea but if you wish I will investigate exact position of the photocell that the printer uses in conjuction with the paper detect sensor to know when paper is present, but before I do I need to get you to understand theconserqenis.
When the paper is out, the machine will not know and will seek to feed ie drives feed rollers, now there will be no paper to slip, in fact the rubber feed rollers will try to feed the base of the paper tray, you are likely to bust a gear, or at least wear the rollers out
due to friction from feed rollers on paper cassette.
Do you understand....
Posted on Jan 24, 2008
  • 4 more comments
  • Soulvisitor
    Soulvisitor Jan 24, 2008
    If you can ensure it never ever runs out of paper then you will not have a problem, but if it does........ it is not good on feed mech.
  • Soulvisitor
    Please confirm that you are speaking of the standard 250 sheet tray "A" that pulls from the front of this machine because on some models they also have the 350 sheet tray fitted "B", there is also a manual feed tray that one can use for up to 100 sheets on the right side "c", you could use that as well if you have a broken lower cassette paper detect lever.
  • Soulvisitor
    I take it that this is the part that is broken
  • Soulvisitor
    I DO NOT RECOMMEND THE FOLLOWING REPAIR, IT IS LIABLE TO CAUSE DAMAGE.
    Open right side cover locate paper detect switch remanent in centre use pic above as a reference, switch if it has a bit left on it of the arm then fix it in up position.
    Better off going to a ricoh print dealer in your area and ordering switch and replacing it.
  • Soulvisitor
    I think This is the part? LINK
  • Soulvisitor
    or does yours look like this (well did)
    http://www.precisionroller.com/sensors-f...
    Genius:
  • 1,067 Answers
Is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Posted on Jan 22, 2008
Paper tray is full but display still reads to load paper. There is a small sensor? dohickie hanging down inside. It was loose. I reconnected it but am not sure how it fits inside the machine. Pushing in...
Hello info66414,
Welcome, and thank you for using FixYa!
You are correct! The Do-hickie is actually called the "Paper Tray Sensor Flag" and it isn't supposed to be dangling down. When it is dangling and won't stay seated, it has been broken by accidental replacement of the paper drawer.
You will have to get ahold of your local Ricoh Repair shop and have them replace this sensor for you. Then it should detect paper properly again.
Have a great day!
Sep 12, 2011 | Ricoh Aficio 1515 All-In-One Laser Printer
It tells me to load paper in tray 2 but the papers full
first check that sensor feel with sensor or left motor is not deafective paper sensor with stick exmine that is touch paper
Apr 01, 2011 | Ricoh Aficio 2020D Copier
The copier is jammed - the copy light and load paper light is on and I can not get the copier to reset.
Have you removed the paper tray to see if there is a piece of paper behind the tray ? Paper will frequently go behind the tray and wind up in the size switches and or the tray lift gears.
I would check that first. Let me know.
Aug 11, 2010 | Ricoh Aficio 1515 Black and White Copier
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic 91009d0.jpg
Apr 15, 2009 | Ricoh Aficio 1013F Copier
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
512 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
