Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Scanner was erased
I have a brother LC-51 all in one printer and the scanner icon was erased and I don't know how to get it back. It is not in the recycle bin. I have also checked on my computer, under contol planel for printers & other hardware in scanners & cameras and it is not listed. Please tell me how I can get it back. Thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
There's a couple of things you can try:
1. Mostly likely you are using a usb cable (cable from the computer to the printer). Unplug this from the printer and then back in. See if the icon for the scanner comes back.
2. Reload the Brother Software. I believe it uses paperport for scanning.
3. Run system restore. This is under your pick a task section in Help and Support for XP. If that's what you are using.
Posted on Jan 22, 2008
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Printer/scanner won't work
Should just be 1 disk for the install. Go to your devices and make sure your printer is plugged in to the power and to the computer. Click on add a printer, select add a local printer, and the computer should scan and recognize your plugged in printer and install it again. If your computer doesn't see the device, check your cable.
Mar 31, 2010 | Brother MFC 6490CW InkJet Printer
Please help, when start the display "unable change 51"
is Internal printer error need to go local repair store (46 is ink pad full) 51 maybe is a scanner problem, or fax board broken.
Nov 22, 2009 | Brother MFC-260C All-In-One InkJet Printer
I have black ink in my printer brother lc-51
Its because grayscale is selected in colors section.
Sep 26, 2009 | Brother Office Equipment & Supplies
How to use black only cartridge on a brother LC-1000BK printer/fax/scanner machine
i haven't got a brother but most systems are the same if you got to print setup on the document on the bottom of the box that comes up there is printer click on that then on the next box you will see properties click that and you will be given the choice of colour or black and white hope this helps regards Jim
Apr 26, 2009 | Office Equipment & Supplies
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
I changed my cyan cartridge in my Brothers LC-51 printer. The display shows No cyan cartridge. Will not print. Replaced with the old cartridge got the same message.
Same issue for lc-51 printers:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc440cn_all
Jun 15, 2008 | Brother Office Equipment & Supplies
Scanner for Brother MFC-3240C
yirabella
I need cleaning my scanner is lock no printing
Feb 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
