Question about LG GCC 4480B CD-RW/DVD-ROM Burner
Dvd burner door stuck open will not this the end of it????
  • Anonymous Feb 17, 2008
    I have a Liteon DVD burner and the door wont close. I can see two little wheels under the door. It looks like some kind of pulley. I would think it had a belt or something and is to make the door open or close. I have been searching to find out about this and have had no luck. I would be so grateful for any information on this subject. Thanks in advance.
  • palamuot Sep 18, 2008
    I have the same problem w/ my Pioneer DVR-109; door stuck open. It will attempt to close but stops.
Hey Even i am facing the same problem.
I wrote one DVD-R.. then i inserted it to check it.
I got stuck inside. I just purchased a new Moser baer LITE-ON DVD Write two weeks back.
wat shall i do,.. Plz help me.
Posted on Feb 26, 2008
Not burn dvd in dvd rom
Posted on Jan 22, 2008
2 Suggested Answers
  • 260 Answers
SOURCE: the cd door is stuck - i cant open the door or close it, help?
There is a small round hole in the front of the drive. Insert a paper clip in the hole and it will release the door.
Posted on Mar 16, 2009
Somethhing got stuck in the dvd/cd burner
Many computers have a small hole in the door to the dvd/cd drive. It is the perfect size to put a paperclip into. Straighten a paperclip and poke the end into the hole, this forces the door open. Hope this helps
Apr 06, 2012 | Dell Studio One 19 PC Desktop
Drive door stuck and wont open
You can always try getting a jumbo paperclip, unbending it once, and inserting it into the small circular hole on the front of your drive. If your drive doesn't have the hole, then you'll have to probably take it to a repair shop.
Good Luck!
Jan 23, 2010 | Sony (DRU720A) DVD±RW Dual Layer...
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Nov 11, 2008 | Philips PCRW (PCRW404) CD-RW Burner
My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Jul 04, 2008 | Philips Televison & Video
Physical Problem with arm of Amigo II DVD duplicator
Could be a bad door sensor. What error message do you get once you close the door?
- techwaredist
Feb 14, 2008 | Rimage Producer Amigo II (555501-210)...
LG GCC 4480B CD-RW/DVD-ROM Burner Logo
536 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
