Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Missing Color. When you start the tv cold it starts missing a color. In dynamic the screen flickers horizontally with the same image only containing all the colors, if you are lucky 1 + 1 = 2 and all the color eventually "merges", though this only lasts for a couple hours. If 1 + 1 <> 2 the flicker eventually just stops and the missing colors remain missing. In Standard or Cinema the horizontal flicker is infinite and never ceases. I have removed the color wheel, it spins. I have tried removing the jumper CN810, color seems to be present after but it is not quite right, too bright, off color.
    Sergeant:
  • 395 Answers
The color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Posted on Jan 22, 2008
6ya staff
SOURCE:
Sony kdl46ex710 half screen 3 colors vertical
This CAN BE a defective panel, but most likely defective capacitors in the power supply section of your TV, and one that requires a good deal of soldering skills not to mention diagnostic ESR meters and capacitance measuring devices to troubleshoot this. Are you sure you're up to this?
Mar 16, 2014 | Televison & Video
Color problem on Toshiba CRT TV
It sounds that the color mask inside the picture tube have been displaced due to hard shock. If so, it is irrepariable.
May 28, 2013 | iLO 2600 Television
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Mitsubishi VS 45607: 1. TV starts out as B/W when first turned on. After about 30-60 min, the color is restored, although not in the full color spectrum. 2. TV flickers a lot vertically. After about an...
You have a bad video board. If you can find one used it is fairly easy to replace once you get into the TV itself. Your color guns could also be adding to this problem. I am not familiar with this television and its components so I dont know if you can replace one color gun at a time or if once one is shot then all three have to be replaced. That should be a start for you anyway.
Feb 25, 2011 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Screen is black and white
You could have a color burst signal missing from the horizontal circuit. A color killer circuit problem or a croma processor circuit problem. If your not a tech, you should have this checked out by a pro, if you want to infest mony into a picture tube type set.
Sep 02, 2006 | Hitachi 27FX49B 27" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
318 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
