Whirlpool Agitator I have a whirlpool Washer LSC 9355DQ0 bought new in 1995. Virtually no problems until now.  Agitator barely moves during wash cycle.  Will move if I spin it by hand or add pressure, but inconsistent.  What are the possible issues?  Is this an easy home fix or best serviced by a professional?
  • Emmit Jan 24, 2008
    ok info
    Master:
  • 619 Answers
Hi , need to service by a profesional repairman near you,some parts to replace like bushing .
Posted on Jan 22, 2008
Whirlpool top load washer. Agitator seems to be wearing out. It barely turns now. if you apply pressure to top of agitator during wash cycle it will agitate. Sound like the agitator is stripped out so...
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 17, 2010 | Whirlpool Washing Machines
Tip
Noise from Whirlpool/Kenmore washing machines / agitator not turning
Many toploading Whirlpool (and Kenmore -- they're made by Whirlpool) washing machines have a ratcheting agitator. The agitator moves only one direction instead of back and forth. There are small pieces (called agitator dogs) that allow this to happen. However, since they are mad out of rather soft plastic, they tend to wear out. The result is a ratcheting or growling noise during agitation (wash cycle) Luckily, they are reasonably cheap (usually under $20) and relatively easy to fix. Try to turn the agitator by hand. It should turn freely one direction and not the other. If it goes both ways freely or clicks and slips one way, you need new agitator dogs. Pull the cap off of the top of the agitator (there are usually two tabs on the side that must be depressed to do this) Remove the bolt in the center of the agitator. Pull out the plastic plate that is on top of the dogs (again, you may have to move two tabs to pull this out.) You should see dogs that look just like the new ones except with no teeth on them. Pull the old ones out and put the new ones in the same way. Reassembly is the same as disassembly except in reverse. It should be quieter and wash better now, as the agitator was barely turning before, if at all.
on Dec 02, 2009 | Washing Machines
WHIRLPOOL MODEL LSQ8543J TOP AGITATOR DOESNT MOVE. THE BOTTOM AGITATOR MOVES FINE DURING THE WASH CYCLE BUT THE TOP AGITATOR HAS STOPPED MOVING. HELP!!!!! WHAT COULD THE PROBLEM BE????
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator barely moves during wash cycle, spin cycle is fine, agitator will engage during wash cycle if I apply pressure by pressing down on the top.
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator disengages intermittently during washing. During the wash cycle it makes a noise like it's unbalanced. Opening lid to watch washing shows the agitator being engaged in fits and starts. ...
On a Whirlpool manufactured washer, the problem may be very simple, inexpensive and easy to repair.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Jan 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitator is barely moving - I am not sure if is fully engaging during the wash cycle? How can I check it out?
If the agitator is working it will move slightly, then back - over and over again and cause the water to, well, agitate.
If you have the machine set to delicates it might not come on full force.
Usually you can check it out by opening the lid during a wash cycle.
If it's barely moving then you might have drive/belt issue.
Dec 07, 2009 | Whirlpool LSQ8000 Top Load Washer
When I look in, it is barely agitating... the agitator is moving a little, but not much.
remove agitator and check shaft spline...if spline is good, clean and put on a new agitator
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Nov 02, 2007 | Washing Machines
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
