Question about Sanyo PLC-XT11 Multimedia Projector
Lamp turns off when projector is upside down
Any suggestions?
    Sergeant:
  • 395 Answers
Check the lamp door switch or the lamp door for warping.
Posted on Jan 22, 2008
Display upside down
you can set the image by setting in the Menu
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 24, 2014 | Panasonic ET-LA735 Projector Lamp for...
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
HOW DO I CHANGE THE BULB IN A MP610 PROJECTOR
You need a smallish phillips head screw driver. Disconnect any power cords.Turn the projector upside down with the front facing you. On the back there is a 3" or so cover secured with one small screw. Remove the screw and the cover. You will see the lamp assembly. On the right is a white cable connection. Disconnect it. On the left is one screw securing the lamp assembly. Unscrew that, then lift the lamp assembly out of the projector housing. Now your options are to replace just the lamp or the whole lamp assembly.
Sep 25, 2011 | BenQ MP610 Multimedia Projector
Image upside down
You have to access the menu with the remote and scroll through until you find image page and then reset it.
May 19, 2010 | Sanyo USHIO PROJECTOR LAMP, Projector Lamp...
If I turn on the main power switch to my projector, the led's on the power switch and the 4 way (left, right, menu exit) switch come on, however, the power indicator does not nor does the lamp. I just...
I had the exact same problem, I followed the advice of Victorbello on this site, and found a bulging capacitor where he suggested to look. Read where below.
I soldered in a new one from Radio Shack ($1.50) and the projector works again.
PB6200 symptoms: Back fans were not working Bulb won't light (but is in perfect condition) LEDs on control light, but not three status LEDs Internal fan will not turn off.
Solution: The mainboard had a bad capacitor The board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard.
The bad capacitor on my projector was a 25V 470uf 10mm diameter, 16mm high, 5mm lead spacing capacitor.
"I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top."
Apr 11, 2010 | BenQ PB6100 Multimedia Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
Image upside down
Check in the settings. One of them will have the option to invert the image not sure what it will be called. That should flip it upside right. I had the same issue with my projector when I first got it just messed with menu until i found it.
Feb 11, 2009 | Epson (V13H010L13) Projector Lamp for...
Benq pb6100, light bulb does not on, power ok
I fixed the exact same problem on my PB6200. Both back fans were not working, and the bulb would not turn on.
In my projector, the fan board had a bad capacitor. The fan board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard. The bad capacitor on my projector was coded C7302 on the schematics. It's a brown, 25v 470uf capacitor.
I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top. You can find pictures on the net.
Jan 22, 2008 | BenQ PB6100 Multimedia Projector
Sanyo PLC-XT11 Multimedia Projector Logo
110 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
