Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
How do I solve the problem of a spoiled tempered glass hob surface due to a corrosive detergent. The surface is becoming bad to worse day by day. Please help.
    New Friend:
My tempered glass shower doors are streked.
i tried everything
Posted on Apr 19, 2010
SOURCE:
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Clean my aeg hg795540xb glass gas hob
Customer always needs to follow the manufacturer's instructions about cleaning and maintaining the appliance. If there are some ambiguities then you should contact an authorized service center. I personally believe that it is not a good idea to clean hob with steam cleaner.
6.3 Cleaning the hob
• Remove immediately: melted plastic,
plastic foil, and food with sugar. If not,
the dirt can cause damage to the hob.
• Remove when the hob is sufficiently
cool: limescale rings, water rings, fat
stains, shiny metallic discoloration.
Clean the hob with a moist cloth and
some detergent.
After cleaning, rub
the hob dry with a soft cloth.
• To clean the enamelled parts, cap
and crown, wash them with warm
soapy water and dry them carefully
before you put them back.
Dado
Dec 31, 2014 | AEG Dishwashers
How do ya cut plate glass and what tools are recommended?
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Nov 19, 2014 | Building Materials
Free download whatsapp
i am unable to download ur whatup apps
Oct 25, 2013 | iPhone Apps
Pinball keeps bouncing up and hitting the glass, is this going ot scratch or break the glass?
Pinball machine glass tops are made out of tempered glass, they would have to take a direct hard hit to break. I've been playing for years and nothing has scratched or cracked yet so you shouldn't worry about it.
Oct 03, 2013 | Video Game Consoles & Games
Glasses in top rack are covered by an opaque film. Seems like the insides are collecting the most. I've tried the white vinegar wash and it worked the next time but the following load was worse.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 18, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The dishes, moeetly the glasses and silverware are cloudy. I don't think its etching. I think it is soap. I can't get it off. I have tried different soaps and rinsed agents and nothing helps. It is...
You can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
If soaking or cleaning with vinegar works then try adding some to each cycle to see if the clarity of the glasses improves.
Dec 09, 2010 | Maytag MDB6650A Built-in Dishwasher
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
How do i solve the problem of a spoiled tempered glass hob surface due to a corrosive detergent. The surface has become dull and lost its luster. It si becoming bad to worse day by day.
you get some good card and wrap it around a sanding block then get some metal polish like "brasso" pour it on the glass and rub . a power sander with card will be quicker
Dec 17, 2009 | Kitchen Ranges
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
127 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
