NO. The comlpete dash has to come out. You may want to replace the a/c evaporator, there also prone to leak and it woill be cheaper to do both at the same time. Recalls are only for safety reasons, Dodge doesnt care about heater cores, (or any other components) as long as they last through the warranty period.
If there is indeed a recall, then the dealer should take care of the issue for you. That would be my recommendation, as replacing a heater core is not a fun job. Good Luck! I hope you find this to be very helpful!
I'm sorry. I missread your post...In a hurry I guess, you were asking if there was a recall, I thought you were stating that there was one, and the other expert is partly correct, in most instances recalls do have to do with safety, however, if it is determined that there is a defective design in a functional part, then yes, occaisionally there will be a non-safety related recall. However, I have researched and do not find your heater call to have been recalled. In order to change out, you will likely have to remove the dash to get to it. Good Luck!
