Question about Toshiba TDP P4 Multimedia Projector
No light The fan is running but we have no light. we did purchase a new bulb and after installation, still no light!?!?!?
    Problem Solver:
  • 9 Answers
Most likely the lamp ballast in the power supply is blown, this was common in the P4 units. These units are more than 4 years old. They were OEM from InFocus. You can check on ProjectorCentral.com for cross reference info to the P4 (for parts info). Your unit may need repair, however it may cost more than the unit is worth (est. $150-$300) I can recommend PROJECTOR DOCTOR in San Diego CA, or ALLTECH ELECTRONICS in New Jersey for repair of this item. PJ DOC might have parts as they were a InFocus repair center as well.
Posted on Jan 22, 2008
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Dimmer isn't working nor the home shield light setting
I would double check the wiring of the fan. Is the remote an add-on that was purchased separately, and did it include a receiver unit which is installed in the fan housing? If so, I would double check the wiring of the receiver unit.
Mar 30, 2014 | Honeywell Handheld Ceiling Fan Remote...
Avion ceiling fan
Did you check the old bulb in another lamp or check the new bulb in the fan yet. The light has a it own switch and you gotta access it's wiring to it to check it out.
Sep 10, 2013 | Heating & Cooling
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
My daytime running lights on my 97 sunfire don't work. inside the indicator light flashes. What could cause this? How do I fix?
this may sound ironic but the cooling fan uses the same circuit you may need a new fan motor
Aug 25, 2009 | 1995 Pontiac Sunfire
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Light bulbs burn out
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
Feb 18, 2009 | Aloha Housewares (93645) Ceiling Fan
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Toshiba TDP P4 Multimedia Projector Logo
225 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
