Question about Maxtor Hard Drive
Bad sector Dear Sirs . I have problem with my hard drive, and I have many important data on it, the system couldn't work properly, I tried to scaned with DOS it has many bad sector on it. My question are : - Causes Band Sector cames - How to fix it ? - Is there any software to solve my problem Thanks You to pay attention Bs Ade arifin e-mail : ade_fien@yahoo.co.id
  • arifin Jan 22, 2008
    Thanks you. I appreciate you have done! it's helpful for me.
    Br Ade Arifin
    Scholar:
  • 67 Answers
I was looking on http:// freeware arena.com and noticed a download that claims to be able to recover data from almost anything.
Virus?? Have you checked?
HDD's tend to go bad as you are describing, "bad sectors" ever increasing, even after format more turn up. Not good. New disk required?
Posted on Jan 22, 2008
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
How can i cleaned my hard disk from bad sector by win 98 or Crystal?
What? No. If your disk drive is going bad and reporting bad sectors it couldn't work around, you need to back up your data to e.g. an exact copy of your old partitions at the end of a new drive. Then, install a current operating system like Ubuntu or Fedora 15 or even LiveCDs, and set up antivirus utilities, etc. You can't 'clean' it any more than you can replace your own spleen.
Jun 06, 2011 | Computers & Internet
My hard drive got bad sectors
if ur hardrive has bad sectors you mite have to replace it u can usally get a cheap hardrive off of ebay.
Apr 10, 2011 | Computers & Internet
I have a gateway t-1620 and on startup it says SMART Failure Predicted on hard disk 4: WDC WD2500BEVS-22USTO-(SI) WARNING: Immediately back up your data and replace your hard disk drive. A failure may be...
Hard drive going bad, you need to recover all your data as soon as possible. It is likely that the RSC has exceeded the space allocated to spare disc space, however, you can check this by downloading and running HDD tune (freeware) to ascertain the disc health and any bad sectors, if there are more than 2 bad sectors and the RSC on the health page is shown in red or yellow, the drive needs replacing
Jan 04, 2011 | Gateway T-1620 Notebook
PLEASE, I HAVE A DELL D610 LATITUTUDE LAPTOP AND I WAS WORKING WITH BEFORE A BLUE SCREEN APPEARED WITH SOME ERROR MESSAGE, AND NOW THE HARD DISK IS NO LONGER RECOGNIZING, WHEN IT DOES IT ODSN'T ALLOW ME TO...
Blue screen error may generally appear for three important reasons : 1.If you system is infected with some viruses and your hard drive has bad sectors in it.
2. If your memory card has gone bad or not properly pluged.
3. The OS has gone corupt due to virus attack.....
Resolution: 1. Go ahead and do a complete format on your hard drive and then install the OS, i.e., Win XP.
2.Try replacing your Memory Card in your system.
3. Change your hard drive or conatct Geek Squad @ 1-800-433-5778 for data recovery.
Jul 29, 2010 | Dell Latitude D610 Notebook
My sandisk cruzer says it is not formatted. it contains all my documents but I cant open anything if i format it i will lose all my data help!!!
Possible Reasons:
1. Your USB flash is too old and can be corrupted with time went on. As you know no hardware can be life-long ever.
2. There are bad sectors in the specific area of the disk that is required for a file system, e.g. for a boot sector or the FAT table sector. Since such a drive is obviously not possible to use, Windows refuses to format it.
3. Sometimes, you cannot format the drive to the FAT file system if it has been formatted to a file system which is not recognized by Windows. Such a drive should be reformatted to NTFS first, and then to the FAT file system.
Solution:
Step 1: Try the problem USB on another computer (better be most common Windows OS). See if the device can be accessed normally. This way can clear the buffers and eliminate incompatibility. Sometimes it will let the error disappear and make the drive work normally again.
Step 2: If the first method still won't help. Try recovering the data with some data recovery programs first of all. If you are running Windows, you can use Data Recovery for Windows. For Mac OS X users, turn to Data Recovery for Mac
Step 3: After the files are recovered, then follow those steps to try format the error USB drive (connect the disk to your PC first). My computer -> Properties -> Manage -> Computer Management -> Storage -> Disk Management -> select the problem drive and then format it from here.
Step 4: It's not over. After formatting, try use the data recovery software recommended in #2 to re-scan the drive to see if you can harvest more data. Good luck!
Feb 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
BAD SECTORS
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Maxtor Hard Drive Logo
123 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
