Question about Pioneer GM-X962 Car Audio Amplifier
Wiring my subs to my alpine mrv-1000
I want to wire 2 infinity reference series subs to my alpine mrv 1000 amp. i want to connect them to bridge them to get them to hit much harder. but when i do this the amp shuts off and over heats? i have 5 gauge power wire. 5 gauge ground wire about a foot and half long. what can i do to fix this?
  • haedyn schaumkell
    haedyn schaumkell Feb 19, 2014
    you may have your gain turned up to much i had this problem i rectified the problem by turning the gain down 0.5v and found that the amp wasnt turning off to get the most out of your amp google the specs up and youll be right mate
It is simple. The MRV1000 can be bridged but only to a 4 ohm load. I am assuming your subs are 4 ohms and run fine stereo, but if you bridge them it will show a 2 ohm load bridged to the amp which means 1 ohm per side. The amp is not stable at the impedance. Get 2 ohm/8 ohm subs or "Dual 4 ohm voice coil" Subs and it will crank fine.
Posted on Apr 10, 2008
  • 107 Answers
Did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Posted on Jan 26, 2008
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
How do I bridge this amp to run a single sub?
  • To bridge 1 sub with a Alpine MRV-100M amp you run the negative and positive wires coming from the speaker to the outside terminals on the AMP respectively.
Regards, Tony
May 22, 2011 | Alpine MRV-100M Car Audio Amplifier
I just bought two rockford fosgate t1 twelves duel voice coil 4ohm I'm running a old school alpine v12 1507 mrv 2channel. I want to bridge the amp to get the most out of these subs would it be better...
This amp should run comfortable at 2 ohms/channel. However, your dual voice coil subs are rated at 4 ohms. This means when you connect the 2 voice coils together in parellel (positive to positive and negative to negative both coils wired to one output) the amp will see 2 ohms. So if you connect both subs to one output then your amp will see 1 ohm (not good) If you run the voice coils in parellel but the subs in series then the 2 resistances (ohms) will be added together. So that way the amp will se 4 ohms. This is fine but the amp would push more power into 2 ohms. You can run one sub on each channel if you can split the head unit output to 2 outputs, problem is then you will be halving the amount of power to each channel. Personally I would probably be more inclined to run 1 sub on this amp and run another amp from the pre-outs on the first amp for the 2nd sub. Try to find another amp the same to run the second sub. Mind you, 2 of these amps will need some big power cable to run them but should shake your teeth out!
Hope this helps
May 08, 2011 | Alpine Car Audio & Video
What is the best way to wire two alpine SWR 1222D subs to a alpine PDX 1000 1
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Sep 16, 2009 | Alpine Car Audio & Video
How do i run it 2 ohm stable
This is how 2 type r's are wired to one amp at 2ohms hope this helps dont forget to rate me thanks
Upfront Audio :)
Apr 06, 2009 | Alpine MRV-1507 Car Audio Amplifier
Wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Feb 01, 2009 | Kicker 02S10L74 Car Subwoofer
1211a amplifier
if your amp. work in bridge you can attach + 1st channel and + 2st channel to your sub woofer. by series 2 ohm you have 4 ohm sub woofer.
Sep 26, 2008 | Infinity Reference 1211a Car Audio...
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Apline mrv-1000 2 infinity sub
RMS power at 12V 20Hz-20kHz
2 x 100W @ 4 ohms (0.08% THD)
2 x 200W @ 2 ohms (0.3% THD)
1 x 400W @ 4 ohms bridge (0.3% THD)
That amplifier is not 2 ohm mono stable in bridged mode (assuming subs are SVC 4ohm).
It is seeing too much resistance and overheating. Thermal overload protection kicking in.
The phase switch allows you to switch from in phase to 180* out of phase. This feature is not to taken as written in stone. In some rooms, or locations of a room, the output will sound louder/better either in phase or out of phase. So there is no correct setting. It all depends where the sub is located and the acoustics or shape of the room.
Phase is term that describes multiple characteriscs and behavior of a speaker system.
Phase alignment: The vertical alignment of the voice coils of all the speakers in a speaker cabinet, so that all signals reach the sweet spot at the same time.
Crossover phasing: If one or more crossover slopes are of a different slope, then the speakers would not fire at the same time, causing delays in response.
Reverse polarity: You may reverse the polarity of a speaker to make the speaker fire inwards instead of outwards to improve alignment with the other speakers in the system. This is very common in tweeters circuitry. As for woofers, if the polarity is reversed, there is usually a cancellation of bass, to a degree.
Jan 22, 2008 | Car Audio & Video
Alpine MRV-1507 Running 2 Alpine Type R 1242D
If you are not using a capacitor at this point, i would recommend getting a 1 or 1.5 farad cap and adding it to the system to take some of the strain off of your electrical system.
next on the agenda is your speaker wiring, the mrv-1507 runs around 900 watts at 4 ohms bridged.. your speakers (I believe) have dual voice coils, so 4 connections total, if you are running 2 of the speakers this will be 8 connections total, in order to match the impedance of the amp you will have to wire the speakers in series/parallel. if you have never done this before, it is easy and will ensure you are running the set at 4 ohms (which will make a huge difference in and of itself).
take both speakers out, you are going to want to wire the positive from one coil to the negative of the other on the same speaker. do this to both of them, this should leave you with one positive and one negative unused on each speaker. now you want to hook both of your free negatives together and run it to the negative on your amp, then repeat the process with the positives.
this is going parallel (4 ohm / 2 coils = 2ohm) and series (2ohm x 2 bridged coils = 4ohm).
now your rms on the speakers is 500 watts each, so matching them to a 900 watt or so amp should work great.
when you are installing the wire, make sure the gauge is correct for the length of run and for the wattage, also connect your power directly to the battery or to a distribution block that is capable of handling the power. in all of my installations i run 0 gauge wire from the battery to a distributor block i mount on the firewall, then i run anywhere from 2 to 6 gauge wire to the amp depending on the wattage and run length.
for your purposes, if the length of wire from the battery to the amplifier is 13 feet or less, 4 gauge wire should be fine, if it is between 13 and 20 feet, i would consider buying 2 gauge wire for the install.
you didn't mention what size your fuse is, but i am going to assume it is 90-100 amp, for a 1000 watt amp i use a 150 amp fuse. if you can find a 130 amp fuse it should work fine.
a major thing to remember when installing an amplifier is that your vehicle's charging system was never meant to accommodate large loads for an extended period of time. connecting direct to the battery, using a stiffening capacitor, and properly matching impedance will go a long way towards helping to overcome the limitations. in the future, if you decide to go all out on this project, i would recommend getting a high output alternator, a battery isolator, and a deep cycle battery for the audio equipment. this will insure that you never kill your primary battery, and that you won't run into issues down the road with your vehicle electronics.
i hope this helps you out, if youhave any further questions, feel free to ask.
trin
Nov 14, 2007 | Alpine MRV-1507 Car Audio Amplifier
Pioneer GM-X962 Car Audio Amplifier Logo
1,306 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
