Question about Samsung CLP 300 Laser Printer
Laser printer problem
I was printing a document of 6 pages and 5th page only came out 3/4 of way and stopped. I pulled it out rest of wayshut the printer off, waited 40 seconds and started it again. I also opened up the back but cannot see anything. I shut it off again and then started it again nothing. Any suggestions appreciated.
Lynda
  • 3 Answers
Did you remove the imaging unit?
There are three places for paper to get stuck, in the rear panel, behind the imaging unit, and in the paper tray.
The imaging unit is the large piece that the toner cartridges mount in. To check behind the imaging unit, open the front panel and pull on the green handle near the bottom. The entire printer will seem like its coming out. Thats fine. put it aside and look for jammed paper.
Posted on Mar 12, 2008
Brother 4800 printer how to print on both sides
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Apr 28, 2012 | Brother MFC 4800 All-In-One Laser Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Lexmark Optra 312L Black & White Laser Printer will not print properly
it's toast...
get another brand, and recycle that one responsibly.
May 21, 2008 | Lexmark Optra E312L Laser Printer
Pause/printer rest between pages
Hi nurse_boop (Lainey), You can try changing some of the printer settings. Assuming you're using Windows, go to Start, Printers and Faxes, and right click on your printer, choose Properties: 1. Make sure that you disable printer pooling; 2. Check/tick, print directly to the printer; 3. Check/tick, Printer is Always Available. Please keep in mind that large file sizes, images and deep colors adds to the slowdown and pauses of printers. Hardware wise, large documents requires more memory both on the printer server PC and the printer itself. Hope this be of some help to you. Post back how things are or should you need further information. Good luck and kind regards.
Aug 24, 2007 | Canon LBP 1120 Laser Printer
Samsung CLP 300 Laser Printer Logo
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
