Question about UC-Logic WP5540U (689076312929)
Pen out of synch
When i connect the pen it jumps around from the starting point on the tablet how can i fix this Problem
  • 871 Answers
SOURCE: Intermittent functioning ...
hi there, you may have a faulty sensor or a loose wire on your tablet. this is the usual cause for tablets to malfunction and eventually die. so my advice to you, if its still under warranty, have it replaced. hope this helps you. ... fixya!!!
Posted on Jan 31, 2008
SOURCE: Wacom Tablet overly sensitive
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
Posted on Nov 02, 2008
  • 41 Answers
SOURCE: My pen wont respond on the tablet
No software aside from drivers are necessary. The Genius Tablet comes a configuration menu you can test. If you don't have this, you can get it for free from Genius' website.
You need to hold the pen close to the tablet to allow it to detect movement. I hold my pen <1cm from the surface. You may want to check the batteries.
Posted on Nov 27, 2008
SOURCE: pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Posted on Mar 19, 2009
  • 31 Answers
SOURCE: my pen is detected but it will not click when i tap.
may be your pen is damaged.
please contact ur engineer.
please vote
Posted on Jul 25, 2009
  • 8 Answers
SOURCE: my digital pen for my pen tablet(bamboo/wacom)
Try hitting the head of your pen into the palm of your hand 5 times and do the same with the eraser. Something about the humidity making the pressure thing in the pen stick idk. I had the same problem and this worked for me.
Posted on Apr 02, 2010
0 characters
1 Points
When I use my pen on my tablet the pointer on the screen jumps all over the place. Whats going on?
Make sure that you do not have anything around you that has blue-tooth or a blue-tooth option. Cell phones, mp3's etc. These can give off false electromagnetic signals causing it to think that you did something that you did not do. Also make sure the batteries in both the tablet and pen are fresh, and that the board is calibrated correctly.
Oct 29, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Cannot open the Pen Tablet Properties page
I just fixed this by fiddling around with it. I use windows XP though.... Try going into your Start panel>Bamboo*or tablet name>bamboo preference file utility.
Then you will have a pop up come up that says to removed, backup, restore
Remove again or cancel. Press the second remove. It will restart your pen tablet.
Hope this helps you.
Jun 05, 2009 | WalkAbout (37429123225)
Point pen fails after falls
I'm guessing something inside the pen was jarred. A basic solution would be to get a replacement.
Also try taking the tip out of the pen and leaving it OUT of the pen for 24hrs.
Apr 20, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My Pen Doesn't Work
ya, i had teh same problem ... i had recenlty downloaded "pen attention" its a software that some guy made to make the pen curser look bigger in one note ... i uninstalled this program and now the problem is gone!!! so just make sure that you delete any programs that you have downloaded tht might be interfeering the the tablet's performance (especilaly programs or addons that my have been developed by non-wacom personelle for the tablet)
Jan 09, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
i had the exact same problems with my graphire4 pen.
take a tool to remove the tip of the pen. just blow inside the pen, put the tip back and press it in back but not too hard. works like magic!
Aug 03, 2008 | Wacom (PTZ930AC) Graphic Tablet
My pen cursor jumps all over the place
You may have an issue with the Graphire pen. Try plugging the tablet into another computer and see if the pen does the same thing there. If it behaves the same way on another computer then you need a new pen from Wacom.
Jun 28, 2008 | Wacom Graphire4 Digital Pen
Doesn't respond to the pen well
I had the same problem, and my fix was really simple. Did you make sure that your mouse and pen aren't on the tablet at the same time? I took my mouse off the tablet, the pen immediately stopped jumping around.
May 26, 2008 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
Graphire4 Pen Problem
throw it in the trash and get a proper tablet
Oct 15, 2007 | Wacom Graphire4 Digital Pen
UC-Logic WP5540U (689076312929) Logo
51 people viewed this question
Top UC-Logic Graphics Tablets Experts
Clive Gray
Are you an UC-Logic Graphics Tablet Expert? Answer questions, earn points and help others
