Microsoft Excel make a formula that can display which is the highest from Num1, Num2, and Num3. Given: Num1:45 Num2:52 Num3:12
  • 27 Answers
= max (Num1, Num2, Num3)
If those values were in cells B2, B3, B4 then then
= max (B2:B4)
Posted on Jan 22, 2008
How to move the result of a formula up or down one cell
go google and type in --manual for excel version (what ever it is ) and down load the pdf file
go to a book shop and buy a Excel for dummies book
or e-bay and excel for dummies or other excel explained books
explaining it as a reply will be as confusing as the reply would be pages long
Oct 13, 2015 | Microsoft Excel for PC
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
How to add two no in c without any operator (even assignment operator)?
This code doesn't include any overflow error checking mechanism. It is not much difficult to implement one however.
#include <stdio.h>
int main(){
unsigned num1,num2,result=0,i=0,temp=0;
printf("Enter the two numbers:\n");
for (i= ~0; i; i>>= 1){ //ensure that the body of the loop is executed 8*sizeof(unsigned) times where 8 is the number of bits in a byte. The number of bits in a byte can be more than 8 on some machines.
temp<<= 1;
temp|= (num1^num2^result)&1;
result= ((num1|num2)&result|num1&num2)&1;//to understand this line and the one above take a look at the full adder circuit above
//here temp is the equivalent of S1 in the full adder circuit above and result is the equivalent of C1
num1>>= 1;
num2>>= 1;
//the bit order in temp would be in the reverse order. the following code snippet reverses the order
for (i= ~0, result= ~i; i; i>>= 1){
result<<= 1;
result|= temp&1;
temp>>= 1;
printf("Sum: %d",result);
return 0;
Here is another elegant solution that uses recursion
#include <stdio.h>
int add(int a, int b){
if (!a) return b;
return add((a & b) << 1, a ^ b);
int main(){
printf("Enter the two numbers: \n");
int a,b;
printf("Sum is: %d",add(a,b));
Mar 05, 2009 | Microsoft Windows XP Professional
Excel Formula
Place the following in the cell you want to display the result:
Logically this reads the cells you have circled, reads the highest #, and places it in the cell you put the formula in. ( you have indicated cell m16 in the screencap)
Hope this is what you are looking for.
Jan 16, 2009 | Microsoft Office Professional 2007 Full...
Excel Formula
Highlight the range of cells that contain the numbers you want included. Click on the cell where you want the highest value displayed. Click on the paste function button select MAX and click <OK>
Jan 16, 2009 | Microsoft Excel for PC
Step1. Start Microsoft Excelmag-glass_10x10.gif and open the file you want to change. Step2. Double-click on the cell where you want the total to appear. Step3. Press the = key on the keyboard. This tells Excel that you are entering a formula into the cell. Step4. Enter the formula, then press Enter. Follow the steps below for an example. Step5. Enter an opening parenthesis character: (. Step6. Enter a cell name. For example: =(E2. Step7. Press the + key. Step8. Enter another cell name and a closing parenthesis character: ). For example: =(E2+E3). Step9. Enter a minus sign and a third cell name. For example: =(E2+E3)-E4. Step10. Press the Enter key to accept the formula. The cell will display the sum of the first two cells minus the third cell. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Tips & Warnings
  • Formulas are just equations. Instead of adding or subtracting numbers you are adding and subtracting the contents of a cell.
  • Excel includes a number of predefined functions to use as well. You can combine the predefined functions into your own formula. (See "How to Use Provided Excel Formulas.")
I hope it helps!!!
Dec 03, 2008 | Microsoft Office Professional 2007 Full...
Addition of two variable
In Actionscript 2.0 the output to the script below will be 15. Make sure that the values for the variables do not contain strings or extra characters like quotation marks. num1 = 5; num2 = 10; sum = num1 + num2; trace(sum);
Sep 28, 2007 | Macromedia Flash MX
Excel Formulas
check this link for all excel formula
Sep 23, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
