Question about Creative Labs Zen MicroPhoto MP3 Player
My mp3 player will display "firmware problem"
Hi my mp3 player will display a firmware problem and i can't even use them...and i don't know what to do...coz every time i turn them on it will go to a recovery mode and it won't work...please i need your help...send me email to those people who are so brilliant in these kind of problem..please i need a good samaritan pretty please...please email me the solution too. tnx guys
Re: my mp3 player will display "firmware problem"
this is the link.. u can get the new firmware download it and install on ur zen.. thats it. its working again.. it solved my problem.. take care guys.. just pray for me..
Posted on Mar 10, 2008
  • 4,402 Answers
Booting straight to the Recovery menu
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Posted on Feb 25, 2008
0 characters
3 Points
Hi, i have here a Sandisk c240 mp3 player. The prob is when you turn it on, only the logo of sandisk appears and it don't work anymore. Even if you press any keys, only the logo is visible. I think...
only the logo of sandisk appears and it don\'t work anymore. Even if you press any keys, only the logo is visible.I think it needs to be reformat or something.Kindly help please
Oct 19, 2010 | SanDisk Sansa c240 MP3 Player
No Display
The firmware is screwed for some reason.. Just upgrade the firmware and all will be fine.
PS: Read your manual properly before upgrading the firmware.
Mar 06, 2008 | MP3 & Digital Media Players
No display
i think that a good firmware update would repair the problem
Make sure it's the good model and download the latest firmware
download it
connect your mp3 player and run the firmware updater
that should reset your mp3 player without erasing your song and display should be ok
Good luck
Jun 19, 2009 | Creative Labs Zen Digital Media Player
Go to the product's website and download the latest fireware available for that model. Then install it. The provider will give the instructions.
Jan 13, 2009 | Creative Labs Zen Touch MP3 Player
Target Base MP3 Player file system error
Unfortunately, the firmware upgrades will not usually result in reloading all the system files from the original firmware. If your unit was displaying "File system error" right out of the box, then your player was probably previosuly-owned. If it is a new problem, a key system file could have been deleted manually or through a basic incompatibility with Windows Media Player 11. At any rate, you will need to go ahead and replace the player if the firmware upgrade does not resolve the issue. Does target even have a firmware update on their website?
-Tha Mp3 Doctor
Jan 02, 2009 | SanDisk Sansa e250 MP3 Player
File system error
File system error is almost impossible fix - you can try updating the firmware (if you actually have an iLo, it will be impossible to update the firmware - manufacturer no longer supports)
Aug 05, 2008 | iLO MP3 Player
"Remove Cable" screen keeps on display
update the firmware by downloading from the samsung website and copying it to your player
Jan 10, 2008 | Samsung YP-K3 MP3 Player
Rca emusic 512 mb mp3 player firmware Problem
I tried to download this but.. i don't understande the chinese but you can try here is the site of the firmaware but it is in chinesse(The page) i for that reason i couldn't download
Oct 02, 2007 | RCA eMusic MP3 Player
Player spontaneously shuts off (battery is charged!)
Hi. I recommend a firmware upgrade. You can obtain this by doing the following: 1) Connect the player to your computer with the USB cable. 2) Wait for "idle" to be displayed on the player screen. 3) Double-click the file that you downloaded from the Rio website. The update should take approximately 30 seconds to load. and here is the link for your firmware upgrade file. Good Luck
Jun 16, 2007 | Rio CE2100 MP3 Player
Display don´t work, the back light, radio, mp3 player work perfect, a change the battery but is the same....
You can try getting the firmware/drivers here - Installing those over everything might solve it, but most chances that it won't. You probably won't find anyone that would fix it for you(techs don't like wasting time working on these little things), so think if you wan't to risk loosing the functionality you have now before opening it up. Saludos
Apr 28, 2006 | Auvi Technologies SA250 MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
