Question about Iwill P4HT Motherboard
Sound problems I have reciently reinstalled Windows xp home. I now have a yellow question mark in Divice manager next to multimedia audio controller. When I try to update the drivers for this it tells me there is no software to be found. How do I get my sound back.
    Genius:
  • 1,067 Answers
Nee dto go to mobo maker dl the drivers ok windows cant wont find them for u who kmake syour mobo maby use reltech sound controlers ok
Posted on Jan 22, 2008
6ya staff
SOURCE:
Hi. I am running Windows XP on a Gateway 450ROG and I have no audio, mixers or otherwise. I have installed/updated drivers, uninstalled and reinstalled, etc. I also have no audio listed in BIOS. Is that...
the yellow exclamation mark your driver needs updating
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Computers & Internet
I have speakers hooked to my computer put there is no sound. it said no divice found what should i do ?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 02, 2010 | Altec Lansing Multimedia Computer Speakers
No sound from PC, problem with multimedia audio controller
The yellow mark indicated the multimedia audio controller driver was not installed, therefore the audio won't work/no sounds.
You need to identify the make and model of the audio card and if you haven't the audio installation CD then you can download the driver from the manufacturer's WEB site.
Since the repairer fixed your computer, he should have installed the audio driver. I suggest you get the repairer to install the audio driver as it should have been part of the repair service.
Also if you see any other yellow marks against any devices in the DEVICE MANAGER then these will also need the drivers installed.
Apr 05, 2010 | Computers & Internet
No sound after reinstaling Win XP
go to HP.com and download the sound drivers
install and restart the comp
Feb 08, 2010 | HP Compaq Business d530 Small Form Factor...
NO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY
click start
then control panel
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
even if there is no yellow !mark follow the steps and update or re-install the driver
Hope this helps
Dec 21, 2009 | Toshiba Satellite M55-S329: M55-S329...
I WANT AUDIO DRIVER OF COMPAQ PRESARIO CQ40-144TU FOR OPERTING SYSTEM WINDOWS XP SP2
1st Download Driver from this site Compaq Sound Driver
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Jun 08, 2009 | Computers & Internet
I need the drivers for the sound card OPTI 16 AUDIO for Windows XP. Thanks for your help.
1st Download Driver from this site OPTI Sound Driver
Mar 20, 2009 | Computers & Internet
Sir my windows media player is not running , it shows sound divice is not installed so how can i install sound divice
Check for the sound driver on ur system... see if the same is installed or not... To acess device manager in windows system... u need to click on Start-> then go to Run -> in the run box just type devmgmt.msc & u'll get th device manager to show up... In the device manager just check for sound video & games controller... If there is a yellow ? mark then u need to reinstall the drivers or else if there is a yellow exclamation mark then there is a driver conflict for the audio device on ur system...
Jan 29, 2009 | Computers & Internet
Presario s4000v
plz try to reinstall your sound drivers
Jan 14, 2009 | HP Presario S4000V (Open Box) (P8655P3) PC...
No Sound... Multimedia Audio Controller Issue
i have a dell dimension 8100 no audio device the multimedia audio controllers has a yellow question mark ive try fixing but cant
May 09, 2008 | Dell Dimension 8100 PC Desktop
Open Questions:
AOL MAil Contact NuMbER [+]{1+/855+/536+/5666-} CUSTOMER HELP call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
AOL MAil Toll Free {1-855*536*5666}#[email protected] NuMbER HAWAII NuMbER call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
See all Iwill P4HT Motherboard Questions
Iwill P4HT Motherboard Logo
Top Iwill Computers & Internet Experts
Ekse
Alun Cox
Robert McClure
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
