Memory card is corrupted when i put it in the pc through card reader it is not opening what can i do to format the card
Just remove that memory card and using card reader connect the memory card to the computer, then format that card.
after formating insert that memory card into mobile and format the card
by using format option in ur mobile....
then it will work as usually.......
SOURCE: my N72 mobile memory card is showing corrupted.how...
when i open my messaging it shows insufficient memory close some application and goes away.
SOURCE: my memory card of N72 is corrupted and it is not showing on the P
if it is you will need to replaced the card
SOURCE: my n72 memory card works fine when i connect it to
hello.. :)
dude,You will need to format your memory card, because i had this same problem and after formatting.. it is working fine..
SOURCE: How to recover datas from corrupted N72 memory card
You may try this mobile phone recovery software named asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
The phone seems to show that the memory is full as there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
my memory card is not inserting my computer show error nit insert disk how to repair it
