Question about Euro-Pro 534DX Mechanical Sewing Machine
Euro pro serger
I cannot figure out how to thread the bottom looper - I have tried a number of different ways and it still doesn't work
  • 1 more comment
  • NAUNNY849 Jul 06, 2008
    EURO PRO 4400X SERGER
  • trevhop Aug 26, 2008
    i was given a euro-pro serger without a manual. i cannot thread the bottom looper. the diagram on the machine is useless to me. there are 3 different diagrams. HELP!
  • Carrie Pickering
    Carrie Pickering Jan 12, 2012
    I purchased a serger needle threader at Joann's fabric it works on the needles
    And the loopers. I also bring the thread around the back of thee looper first to catch. Hope this helps.
  • Euro-Pro Master
  • 1,388 Answers
There is a threading chart here
Bargainbox
Posted on Jan 27, 2008
THANK YOU! I have a europro serger and have misplaced the manual you are awesome thanks for your help. I have been working on a invention and you saved my **** thanks again!
Posted on Feb 14, 2009
6ya staff
SOURCE:
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
My lower looper thread keeps breaking. I rethread it, checked the tension and yet it still breaks.
Please re thread machine from scratch threading upper looper first then lower looper then needles also be sure needles are in with the flat back to the back of machine sequence of threading is imperative
Feb 24, 2015 | Euro-Pro Sewing Machines
Where can I send my Euro-Pro serger to be repaired? I want to send it to Euro-Pro.
  • Visit the Euro-Pro website at euro-pro.com.
  • Click the link on the right-hand side of the page below the text box, which reads "Customer Service: Click Here." This will direct you to a contact page.
  • call the number listed at the bottom of the text box for placing an order, 800-798-7395. Because no direct number is given for customer service, requests to contact a representative are fielded through this number
  • Jan 17, 2013 | Sewing Machines
    Correct threading for 4 th. Juki ind. overlocker
    Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
    The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
    These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
    Aug 31, 2012 | Sewing Machines
    Please help me thread my lower looper! I am totally confused and it is driving me crazy
    Most of sergers thread the same way, go to www.singerco.com, - under customer support, or www.brother-usa.com, (support, home sewing &embroidery, pick the 1034d model) these are free or there are videos on youtube.com. I have 5 different sergers, 3 Singers (14sh654, 14u64a, 14j334), 1 Brother (model 1034d), and 1 Babylock Protege. They all pretty much do the same thing. I have learned that you must thread in the order that your manual tells you for the thread to loop right, all of mine, the 3rd spool from the left is the 1st one to thread. Remember, that you have to go behind the looper, using your long tweezers, and hold the thread end slip it behind until it goes into the notch, then bring you thread along the path on the looper and thread through eye. Have patience, I thought I was going to lose my mind also, until I actually took off the throat plate and saw that notch in that looper, then I knew what to look for. Also, make sure that you pull your thread like they show for the tension discs, very important. Some manuals are better than others, but one of those will click with you. I hope that I have helped you because you will love serging once you have it threaded right.
    Apr 19, 2011 | Euro-Pro 100-545 Mechanical Sewing Machine
    How to thread euro pro serger. threads aren'y interlocking
    If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
    Turn off the power.
    Raise the thread antenna to it's highest position.
    Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
    Turn the handwheel so the loopers are at their highest position.
    Begin threading from the right to the left - lower looper is usually the first to be threaded.
    After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
    Mar 23, 2010 | Euro-Pro Sewing Machines
    Brother serger thread
    The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
    sewman7
    Jun 17, 2008 | Brother Lay-In Thread Serger Mechanical...
    Euro pro serger model 101-548
    3 thread overlocking (serging) is no different t 4 thread, except you remove one or other of the needle threads.
    The stitch width is then controlled by two variables,
    the manual width dial selector, and
    your choice of either the right or left needle
    Suggest yo play with width selector on a scrap of your project fabric to achieve the look you are after.
    Feb 17, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
    Euro-Pro 534DX Mechanical Sewing Machine Logo
    1,022 people viewed this question
    Top Euro-Pro Sewing Machines Experts
    Irene Tulloch
    MissFixIt828
    Level 1 Expert
    Thomas F. Schneider
    Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
