Question about HP PSC 950 All-In-One InkJet Printer
My front panel won't light up, how can I remove to keypad to replace bulb?
The front panel buttons will not light on my PSC950 printer, I removed the top panel but now I can't remove the keypad in order to replace the light below it.
The "lights" below the buttons in the panel are LED's and are not replaceable, also they have a extremely long lifespan making it near impossible to wear out.
If the panel isn't lighting up, your printer has another problem, not burned "lights".
Posted on May 04, 2008
2009 buick lacrosse console gear indicator bulb
Transmission Floor Shift Control Indicator Lamp Replacement
Remove the front floor console. Refer to Front Floor Console Replacement.
Rotate the floor shift control indicator lamp socket (2). Pull the socket from the trim bezel.
Remove the bulb from the socket.
Preliminary Procedures
Remove the rear floor console. Refer to Rear Floor Console Replacement.
Remove the instrument panel lower trim plate. Refer to Instrument Panel Lower Trim Plate Replacement.
Set the parking brake, then shift the transmission into drive and push the shift indicator down until it locks, to allow clearance to remove the console.
Front Floor Console Screw (Qty: 2)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N·m (18 lb in)
Front Floor Console Bolt (Qty: 2)
Tighten
10 N·m (88 lb in)
Front Floor Console Assembly
Front Floor Console Retainer Clip (Qty: 2)
Feb 24, 2017 | 2009 Buick LaCrosse
How do you remove the face panel for the control buttons. My on/off button needs replacing.
Jenn Air Oven Remove Front Panel - YouTube
? 1:46
https://www.youtube.com/watch?v=cEKlbFxONMI
Jan 27, 2012 - Uploaded by travisgrindal
This is a video describing how to remove the front panel off a Jenn Air ... Do you have any for changing the wirings in the back? for the oven ...
How to remove an oven keypad...Part 2 - YouTube
? 10:46
https://www.youtube.com/watch?v=-ACCdMbIvJM
Aug 12, 2012 - Uploaded by VideoJoeKnows
Part 2 Removing an oven keypad is easy...when you know how. ... to have a friend help you with this, but if you need to do it yourslelf, that's fine ...
Safely Removing a Microwave Oven's Control Panel ...
Dec 08, 2015 | Ovens
Sony Vaio VGC-RC210G blue panel light LED burned out. Need to know how to change bulb?
Obviously the question was not answered correctly. I don't know how well you are versed into taking things apart, but here we go. First you need to unplug Sony. You need to remove the I/O panel on the bottom of the case after removing the front panel. Remove the on/off switch and remove the two lights adjacent to it. You gently pry apart the tabs on the back of the bulbs and pull the lights out from the back out of retainer. Do the same with the light that is burned out. Carefully cut or break the two cable ties and remove complete wiring harness. You need to remove the side Panel (right side looking from the front). Remove the air tunnel pieces (2 of them), The cable that needs to be unplugged from the motherboard. it is the very first along top edge from the left. It is yellow. Open the 2 tabs that hold all wiring down the front (you will see these just in front of CPU fan and behind front grill. Remove the harness. I do have the number in front of me but you can take the harness to Radio Shack and they can give you the correct one. Cut the old bulb off as close as possible. Solder the new one on and reverse the steps to reinstall. Once harness is plugged back onto motherboard, you can test by plugging power cord in and pushing power button. Make sure none of the wires are touching each other or any metal. Put it all back together and you will have blue light (light is not blue, plastic in front of it is). OR you can just use it without that light as it serves no purpose to be pretty and no one but you will know the difference. By the way I refurbish, repair, etc. nothing but Sony PCs. You also may be able to find a replacement harness but they are scarce. Hope this help. OH, the power supply or motherboard has nothing to do with this bulb working or not. If the other two (power on and hard drive activity) work, the bulb only, is bad.
Jan 07, 2013 | Sony VAIO VGC-RC210G 1GB DDR2 PC2-4200...
How to replace fog bulb on santa fe 2013
"Replacing fog light bulbs on 2013 Santa Fe". Raise vehicle if you are a big person. In front of front wheels triangular plastic panels exists. Remove Phillips head plastic screws in chosen panel (2ea). Pull panel down. Stick hand through opening, remove wiring connector from bulb. (Bulb will not come out unless you do). Twist bulb housing counterclockwise and remove. Install new bulb, reverse procedure and don't touch the glass part of the bulb.
Nov 20, 2012 | Hyundai Cars & Trucks
Replacing bulb in dimplex electric fire chb20br
To replace the bulbs, your will need to remove the plexiglass front, then remove the logs and set them off to side where they won't get stepped on. Then lift up the plastic simulated ember bed. You now have access to the light bulbs. The required bulbs are 60 watt small base chandelier bulbs.
Hope this helped you, Margo. Thanks for choosing FixYa.
Aug 18, 2011 | Heating & Cooling
Frigidaire Model NMER336FS0 How do I change the interior light bulb in the drum?
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
Jul 16, 2011 | Dryers
How to replace the front buttons?
Most microwaves use a membrane type keypad that is glued to the front panel..they can be expensive though, but aren't too hard to replace...it involves removing the cover...unplugging the keypad ribbon cable...removing the old keypad...and reinstalling the new keypad
Jan 15, 2011 | Sharp R-1500 Microwave Oven
I am getting no response when i push the power button. I have a mitsubishi medallion 65'' 1080p tv. This just happened out of nowhere. there is no blinking light nothing. i noticed that there is power...
Front buttons . Remove the lower front speaker covers/panels by pulling . Then unplug connector ZF to the keypad . Then wait 3 minutes and try to turn it on with the remote . You may have to remove the access panel to find connector ZF (just follow the wiresdown from the front keypad). Don't touch , turn or break anything else while inside the access panel!
Let me know if that works
Oct 21, 2009 | Televison & Video
Stereo light bulb replacement.
deep inside head unit at front is the led to replace .. likely soldered into a board there as a non replaceable part ..remove head unit ..disassemble to get behind front panel...good luck..maybe this is not a worthwhile project money/ time wise.... my 2 cents
Oct 27, 2008 | 2000 Chevrolet Silverado
Scanner failure error
Take the top off and clean the underside of glass as well as the mirrors on the scanner. Remove the bulbs. This is a light job but not for the mechanically impaired. If you have a 7110, take the ADF off by lifting 2 black inserts near the hinges. Remove 3 screws - 2 near ADF hinges and one on the right.
- Pop off the button cover.
- Remove button assy by sliding right, lift up and pull forward. Remove cable and 2 screws in view.
- Pop off the front plastic piece that the button assy. rested on.
- Remove 1 or 2 screws on the underside center of the top glass assy.
- Open printer exposing the print area and remove the front hinges on the bottom by moving the tabs on left and right side of both hinges.
- Remove a few screws holding the top cover in place.
Cleaning the mirrors.
- Remove the top plastic cover on scanning assy by inserting a small flat blade on the left and right (just behing the lights) and release tabs. Lift front upward till rear tabs are free.
- Remove the bulb toward the middle of the scanner assy. by unplugging, unsnake wire and lift up only that end enough to clearing so you can slide the other end out.
- Remove screw holding dont the clear plasic guide.
- Unplug the other light and unsnake wire. Lift that end up only until the clear plastic piece clears guides and then slide both plastic and light until the other end of the light is free.
Clean mirrors carefully and wipe bulbs carefully
Then Reassemble.
Jan 27, 2008 | HP OfficeJet d145 InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
