Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
Having trouble using it as a solo harddrive in newer computer
I am trying to switch out my old quantum fireball lct 15 20 from an old compaq Presario into a newer computer with a faster processor. I can not get the newer computer to start up windows off of the hard-drive, even though it seems to recognize it in the BIOS. Can anyone help?
    Brigadier General:
  • 6,966 Answers
When Windows (XP?) was installed in the Quantum Fireball LCT1520 of the old Compaq Presario, the OS was married to the hardware specifically the motherboard/chipset. When it was removed and transplanted to the newer PC, the OS would be looking for the old hardware settings/configuration and since the new PC has a different motherboard and therefore cannot find the old hardware, it would loop/reboot continuously and/or BSODs.
One method of getting the old HD to work in the new PC is to do a clean/new install of the OS.
If for some reason you prefer to use the old OS in the old HD with its settings/configuration, you can try to do a repair/re-install. The procedure is similar to installing a clean/new OS except that you should opt for the 2nd repair choice (not the R or first repair option). This should retain most if not all of your old applications/settings while installing new Windows files.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 22, 2008
I need firmware for quantum fireball lct 15. thenk you
I have a firmware for fireball lct15 a01.0f00. If you need it give me your e-mail adress and i'll send it to you.
Mar 24, 2011 | Quantum Fireball Lct15 7.5 GB ATA-66 Hard...
Quantum fireball LCT 15
please refer to the following link
http://www.pcguide.com/proc/setup/hdd-c.html
Sep 02, 2008 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Need jumper setting for quantum hdd 3.5 series fireball lct ,LB10A011 10.1gb to set up as a slave hdd ,thanks
Try this if not then get back to me and i will see if i have another diagram. I had to dig for this info too old haha. i still work with this stuff
Feb 27, 2011 | Quantum (LB10A011) Hard Drive
Please email me at duokeystrings@yahoo.ca if you can answer the following: 1.How do I connect internal quantum fireball lct 20 3.5" 40.0 GB externally? 2. Is there a patch cord that will connect from...
this link will show you the only device you will ever need. you can conect any size hard driv or any type hadrdrive to your PC. i use this constantly and its wonderful. also it is on sale for 19 bucks so you would get it 10 bucks cheaper then i paid for mine.
Vantec CB-Isatau2
VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002&cm_re=vantec_sata-_-12-232-002-_-Product
one other thing, Newegg is a trusted site. i have dealt with them for years. if you get a bad part they will stand behind it.
Feb 05, 2011 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Hard disk not recognized
found the solution inside Dell web page - jumper position shown graphically - Thank you, anyway.
Jan 07, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Fireball lct 40 gig friend opened Hallmark email virus on computer. will not run XP
There is a freeware program out there cald 'KILLDISK " that will write 1's & 0's to the HD once and wipe the hard drive - then reformat the HD and start over - I just did this on a compaq 6330 for my buddy using the old **** QML20000LD-A Fireball LCT20 - this HD stinks and it has 1990 size 128kb Buffer and a slow 4500RPM speed
Aug 15, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
152 people viewed this question
Top Quantum Computers & Internet Experts
SirEbrum
terminalcon
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
