Kyocera Mita KM-2550 All-In-One Laser Printer Logo
Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i set up KM2550 to scan - Kyocera Mita KM-2550 All-In-One Laser Printer
Anonymous
Level 3:
  • Master 330 Answers
  • Posted on Dec 16, 2009
Anonymous
Master
Level 3:
Answers
330
Questions
Helped
110623
Points
1037
Install the paper port software from the printer driver cd and use it to scan
Error c3200 on km2550
Clean the slit glass or open the glass and clean the mirrors from the dust.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
KM2550. How do I correct error 960?
go to printer properties, printing preferences and set the paper size to A4 or the size you are sending
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
2answers
Black lines appear when printing on kyocera km2550
could be fuser tracking where the pawls ride on the heat roller, could be abrasions on drum, could be main charge corona, could be LSU glass. Can you provide a sample print?
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Program
    IF it says downloading program it sounds like it is trying to update the firmware. Did someone stick a compact flash card in the CF card slot. If so removed the CF card and reboot the machine.
    Scan to computer
    Several ways to control your scanner:
    From this HP link
    Changing scan settings in HP Director
    Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
    1. Open HP Director, if it is not already open:
      • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
      • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
    2. In the Select Device list, select your product, if it is not already selected.
    3. Click Settings , and then point to Scan Settings & Preferences .
    4. Click the scan setting menu that corresponds to the type of file you are scanning.
      • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
      • Scan document settings : Designed for scanning documents
      • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
      • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
      After selecting the appropriate menu, the corresponding window opens.
    5. Change settings as appropriate, and then click OK . The scan setting window closes.
    6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
    From this HP link
    Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
    Here the main site for the scanner - click here
    2answers
    Won't scan legal documents properly
    Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
    Scanner will not save to computer
    By default, the HP all-in-one sends all scans to the HP Photo & Imaging Gallery for you to preview. Suppose that you want to scan your photos directly to email instead. To do this you will need to modify the destination assigned to the front panel scan button. Here is how to do it:
    1. If you have not already done so, open the HP Director and click Settings , point to Scan Settings & Preferences , and click Scan to… Setup . The Button Settings dialog box appears, with the Destination List tab on top. The HP all-in-one automatically inventories your computer and lists all the possible scan destinations for you in the Available Scan Destinations list.
    2. Using our example of scanning directly to email, select the Email destination in the Front Panel Destination List and click the Move arrow to move it to the top of the listing.
    3. Click OK to save the new destination setting and close the dialog box. All of the scans you do using the HP all-in-one front panel buttons will now be sent directly to your email program, instead of to the HP Photo & Imaging Gallery.
    4. Click Scan Picture or Scan Document in the HP Director to scan using your new settings, or click a Scan button on the HP all-in-one front panel.
    also
    Setting a default scan profile Use the following steps to apply a scan profile to all future scans.
    1. If you have not already done so, open the HP Director and click Settings , and click Scan Settings and Preferences .
    2. Click one of the following, depending on the type of scan profile:
      • Scan Picture Settings
      • Scan Document Settings
      • Button Settings The corresponding dialog box appears. If you chose Scan Picture Settings or Scan Document Settings , the Scan Settings tab is on top. If you chose Button Settings , the Scan Button tab is on top. All of these tabs have the setting you need, Apply Scan Profile .
    3. On the Scan Settings or Scan Button tab, click Apply Scan Profile and select the scan profile that you want.
    4. Click OK . The scan profile that you selected will apply to all future scans for the scan type that you selected.
    Top Kyocera Mita Office Equipment & Supplies Experts
    ZJ Limited
    ZJ Limited
    Norman Weimar
    Norman Weimar
    Ngoro
    Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
