Question about Acer Aspire 3100-1405 Notebook
Usb ports do not recognize flash drives
Although I followed your instructions posted on 1/19/2008 and I uninstalled ports, then restarted computer, the ports still do not recognize any device I insert in the port (it started recognizing one flash drive then it stopped). I went to device manager and each port is reported to working properly!
What is wrong?
  • 1 more comment
  • Anonymous Feb 08, 2008
    Yes I do
  • Anonymous Feb 25, 2008
    I have the same problem i will reinstall the windows xp!
  • PO2008 Nov 27, 2008
    my usb ports just quit working. None of them recognize my ipod and when I plug in my printer or flash drive it freezes the computer up, causing me to have to shut the computer down improperly.
  • 1,067 Answers
Regisrty key maby u could try repairing your windows back it all up redo it maby sum spyware or sumthing if not bad board not powering good engh to usb
Posted on Jan 22, 2008
My laptop won`t recognize my sdcz36-016g
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Jan 01, 2013 | SanDisk 16GB Cruzer Blade - USB Flash...
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I just bought a new Gateway NV53 laptop but my P4350 Lexmark all in one printer does not recognize any of the USB ports.
Did you check whether the USB ports are recognizing other USB devices such as Microvault or Flash Drive? If all other USB devices are recognized except the Printer, then reinstall the USB Drivers. You can uninstall the USB drivers from the Device Manager and restart the Computer. The USB Devices are listed under Universal Serial Bus Controllers in the Device Manager.
Jul 10, 2010 | Lexmark P4350 All-In-One InkJet Printer
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
I uninstalled the driver from my transcen jf v30 4gb pendrive. Now windows says hardware not recognized.
Hi s8vysakh6 ,
I would suggest you to try the following steps:
Step 1: Run the fixit provided in the link below.
Check if the issue is resolved
Step 2: Connect the device to a different USB port\ and also connect the USB pen drive to another computer to eliminate issues with the pen drive itself.
If the issue persists,
Step 3: Reinstall USB controllers.
1. Click "Start", type in Device Manager the Search bar and press "Enter". Click Continue if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows vista will reinstall all USB controllers automatically.
Step 4: Update the motherboard driver to the latest version.
Note: Please check with the motherboard manufacturer before installing the driver.
If the issue persists, you may want to check with USB pen manufacturer for any unknown issues.
Hope this will help !
Mar 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How do I reload the drivers after reloading Windows
Oct 25, 2009 | Dell Latitude D420 Notebook
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Maxtor 3200 error code 10
To uninstall a device
  1. Open Device Manager.
  2. Double-click the type of device that you want to uninstall.
  3. Right-click the specific device you want, and then click Uninstall. You can also double-click the device, and then on the Driver tab, click Uninstall.
  4. In the Confirm Device Removal page, select Delete the driver software for this device if you also want to remove the device driver package from the driver store. .
    The Delete the driver software for this device option removes the package from the driver store. It does not remove the currently installed driver for any other operational devices that use the same driver. If you remove the driver from the store, and the device is connected to the computer again, Windows must search for a copy of the driver package in the standard search locations, including possibly prompting the user for media. This option is the equivalent of running the command: pnputil -d -f <package.inf>. For more information, see Remove a Driver Package from the Driver Store.
  5. Click OK to complete the uninstall process.
  6. When the uninstall process is complete, unplug the device from the computer.
    If you are prompted to restart the computer, the removal is not completed and the device might continue to function until the computer is restarted.
Reinstall a Plug and Play device Reinstall a device only if it is working improperly or it has stopped working altogether. Before you reinstall a device, try to restart your computer and check the device to determine whether it is functioning properly. If it is not, try reinstalling the device.
To reinstall a Plug and Play device
  2. Follow the instructions in the preceding procedure to uninstall the device.
  3. If you are prompted to restart the computer, follow these steps:
    • Plug in the device and then restart the computer. The device will be detected and reinstalled after Windows restarts.
    • Follow any instructions on-screen to complete installation.
  4. If you are not prompted to restart the computer, follow these steps:
    • In Device Manager, in the Action menu, click Scan for hardware changes.
    • Follow the instructions on the screen.
Dec 05, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
SanDisk not recognized by computer
Follow these steps:
  1. Go to START > Right-click My Computer > PROPERTIES
  2. On the tabs, click Hardware > DEVICE MANAGER
  3. Press the + sign next to the Universal Serial Bus controllers.
  4. Doubble-click the first one
  5. When the new window comes up, click Drvers from the tabs, and click "uninstall"
  6. Repeat step 5 for all devices
  7. Restart your computer.
After your computer restarts, plug in your flash drive and it should work.
If that doesn't work, then the USB ports on your computer are dead. You can try to get new USB hardware at a computer store to plug into your computer (THIS IS NOT THE SAME AS A USB HUB!)
Feb 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Acer Aspire 3100-1405 Notebook Logo
518 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
