Power on but no display on Denon AVR 3705
I have never had any problems with my 3805 until Sunday, when the volume changed suddenly, then no volume and the screen display went off.  The green circle Power On/Stand By switch stayed on.  I pressed (turned off) the On/Standby switch and the circle turned to red, as it should.  I pressed (turned on) the On/Stand By switch, the green circle blinked then stayed green, as it should,  but the display did not light up and there is no sound.
I tried powering up using the Power Switch and unplugging the AVR but the result was the same.  The green circle would blink, then go solid green but no display and no volume.
Is there something I might try other than disconnecting the system and taking it in for repair?
  • Icarus Cheng Mar 22, 2008
    Having the same situation with my 1707 last night. Warranty was just expired ONE DAY AGO and would like to see any solutions.
    Problem Solver:
  • 12 Answers
By now the folks who asked this have certainly solved their problem, but in case anyone else has this same question:
If the color change from red to green on the Power button indicator light and stays that way, the receiver is most likely working fine, it's just that your front-panel display is OFF.
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
HOWEVER if the power light flashes rapidly, the amp's overload protection circuit may have been triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component, and make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!) Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the AVR-3803).
Posted on Jan 28, 2010
  • Nashk Sep 30, 2010
    My front panel display stopped working on Denon AVR 3802. It turned out to be the dimmer button on the front.
I have the same problem! Someone please help us
Posted on Jan 26, 2008
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Denon avr-3805 suddenly picture went out on tv (says no signal). Denon shows 'voff' on the screen. I cant figure out what happened.
I called customer support and they had not heard of this problem, and could not even tell me what the "V.Off" showing on the display represents. But, . . . the problem was solved by resetting the memory - by powering off, and powering back on while holding down both the Mode and Analog input buttons. Although this wiped out all my settings, the "V.Off" on the display disappeared, and the video now works. Problem solved.
Feb 14, 2011 | Denon AVR-2805 Receiver
I have a AVR 3805 running my theater room. I'm not getting sound. How do I reset it? My sound guy did that once before and it worked. He cant get here for 2 days though... Any ideas
Turn off main power, press "direct" and "pure direct" simultaneously while turning main power on. The display starts blinking, reset is done.
Oct 31, 2009 | Denon AVR-3805 Receiver
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
1,503 people viewed this question
