Question about T-Mobile Dash Smartphone
Sw reset i tried the sw reset on my t-mobile dash but it just keeps turning on. how exactly does the sw reset work? i might be doing it wrong.
    Problem Solver:
  • 6 Answers
Are you trying to hard reset?
very easy steps...
go to...
1.Select Start
2. Accessories
3. Clear Storage
4. Type 1234 in the box
5. Select YES.
By:PR Link
You can search me at youtube.com/xprxlinkx
Posted on Jun 19, 2008
The phone locked was blocked
Hi what is your mobile model? if its nokia then try default code "0000" or "1234" and if it does not work then try unlocking4free to get master reset code for your mobile by just submitting your mobile's imei number and get reset code to reset your mobile..
Aug 30, 2011 | Nokia 6210 Navigator Cell Phone
My phone doesn't want to turn on!
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Nov 04, 2008 | T-Mobile Dash Smartphone
Windows Mobile 6 Won't Boot
bigsphinx, I too am having the exact same problem on both my phone and my wife's too, about once a month it just locks up then after a soft reset it just gets stuck on the green screen. I called support and they said I just have to do a hard reset, which loses everything :(
So for now I always backup (using PIMBackup) to my SD card for the next time it happens.
May 09, 2008 | T-Mobile Dash Smartphone
T-mobile Dash Won't start
This will fix it:
Turn the phone off, remove the battery for a minute. Replace the battery.
Hold down the right and left soft menu keys simultaneously then press the power button for a couple seconds and release. Keep holding down the soft keys until the hard reset screen displays.
The reset screen will tell you to press 'Send' to reset or any other key to cancel. Press and hold 'Send', which is the button with the green phone on it. After a couple seconds, the device will start to do its thing.
This will take some time so be patient. It will have a question or two as it goes through the process. Answer.
Don't worry, you won't lose your branding (e.g. if you are a tmo customer, you don't lose the ability to have myfavs and your phone keeps the tmo branding/settings).
Apr 30, 2008 | T-Mobile Dash Smartphone
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
Tmobile dash frozen on WINDOWS(DIRECT TOUCH TECHNOLOGY SCREEN)
do a sw reset....its possible it was damaged when it was dropped in the water, but not likey....
turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
Nov 23, 2007 | T-Mobile Dash Smartphone
Dash stuck on the green screen
do a sw reset. turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
Nov 19, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Password doesn't unlock phone
How to reest T-mobile dash if you forgot security password !!!!!!! first turn off device,then keep press both tow - - button under neth screen and the mean time press one time power button after that when screen comes up press green call button one time. then wait and press ok . you r done.
best regards
Oct 26, 2007 | T-Mobile Dash Smartphone
T-mobile dash
How to re-est T-mobile dash if you forgot security password !!!!!!! first turn off your device,then keep press both tow minus - - button (under neath screen ) and the mean time press one time power button then release the button after that when screen comes up press green call button one time. then wait for complete the process and then after finish press ok .remeber your all personal deta will be erase after the reset .
best regards
Oct 05, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
94 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
