Question about GE GSH25JFR Side by Side Refrigerator
My water dispenser is not working.
I have made sure that water line is open and unplugged the fridge and listened for a water noise (perhaps a leak under the house). Another participant on this link suggested that you move the fridge and freezer settings from 5 to 4. Will this work?
    Sniper:
  • 74 Answers
Nope, its imposible to frees that line ,however there are two selenoides in the water in take located in the back of the frigi check if you heard a click sound wen you activate the water switch if not then you have to change the selenoide if yes look for water obstrucion in the water server...good luck and rate me
PS somes time they click but are cloged
Posted on Jan 22, 2008
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Switches on kitchen aid refrigerator dispensers not working.. ice maker is working, but will not dispense ice or water
Sounds like the water has been turned off, or the solenoid valve (located at water entrance to fridge) has failed. you should hear a solid snap from that solenoid when water is called for by pressing the dispensing switch. You can test the solenoid by unplugging the fridge and measure the resistance across the solenoid terminals. If it measures 200-500 ohms it is ok. if it measures open the solenoid has failed and needs to be replaced.
Sep 18, 2014 | KitchenAid Refrigerators
Fridge will only dispense 6 cups at a time?
Some fridges have a safety feature built in, which turns off water if the water valve was open for a certain number of seconds, to avoid flooding. So if you need a lot of water, make sure to release water dispenser lever for a second or two every minute.
If the above is not the case, you may need to replace the water valve or a switch on the water dispenser.
The way to find out which part needs replacement is to check the voltage on the green water valve coil when the dispenser lever is pressed but it's not dispensing water. If 110v AC is present across the coil - replace valve. If there's no 100v AC - replace switch in the dispenser. Make sure to unplug the fridge before opening the dispenser.
Vlad
First Choice Appliance
Jun 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
I have an older Profile that is working fine except it won't dispense ice or water when the door switch is pushed. I checked the switch itself and it is okay. Where do I go next? Profile Model TFHA 22RRA
The water valve is the only other thing that controls both. Go around to the rear panel (just follow the water line to the fridge) and have someone push the water dispenser paddle in the front and then listen. If you hear a hum or buzz noise when they push it. If so the valve is trying to open but cannot and it will have to be replaced.
Jan 19, 2010 | GE Refrigerators
Water Dispenser leaks from rear of fridge
the answer to the problem is behind that back panel.
Nov 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water will not dispense on LSC27931ST fridge. I just installed it, does it take a while before it works? Or is it a filter, line prob...Unit is brand new
Make sure the line tap valve for the water supply is open. Check the filter is installed properly. Be sure both doors are completely closed. Listen for a clicking noise when you press the dispense button (that's the solenoid valve opening). If it's just installed, you will have to hold the dispense button down for several minutes to fill up the filter and the lines.
Jan 05, 2009 | Refrigerators
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active Smart® E522BR...
GE GSH25JFR Side by Side Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
