Question about JVC HD-52G786 52" Rear Projection HDTV
I have found a jvc hd56g786 tv in the trash, one problem the mirror inside was broken i have taken it apart to clean the broken glass up then i pluged it in to check it out, so anyway when it turned on i heard the clicks that it makes( that small click when it goes on) the led light goes on and a blue light the two lights blink at the sametime i know from research it mean malfunction in unit is there any type of sensors in them i thought i might have seen one? will it sense that there is no mirror?
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Posted on May 11, 2008
What and how to take apart jvc hd56g786 to clean mirror. picture is dull
Posted on Mar 04, 2009
I changed the lamp and tv colors are opaque, what I can do to fix this problem
Clean the bulb and make sure you did not touch it with bare hands or you may the wrong lamp so check that also
Oct 14, 2014 | JVC SELECT HD56G786 Rear Projection...
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC tv model HD56G786
It's easy, you just have to go back into the menu setup for the auto channel/tuner setup and rescan for channels. I'd noticed this as well when playing around with the tv when I'd bought it and it had done the same to me.
Dec 10, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Tv problem jvc hd56g786
your lamp bulb is probably finished so get a new lamp bulb they are easy to replace just look for a small panel on the side of you tv all you need is a flat head screw driver to open the panel and you should be able to pull out the lamp bulb
Oct 14, 2007 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
583 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
